304065's Avatar
Porsche Crest 911S Brake Spec
Does anyone have a view as to the wear limit for rotors and pads for aluminum "S" calipers?
The factory spec for the rotor I was able to find:
Rotor 20.0 -.02mm, wear limit 18.0mm
#806 Front 19.4
#806 Rear 19.0 (with lip on outer edge of 19.6)
According to Pagid, the U4503 "S" caliper pad has a thickness of 19mm. So 50% wear would be 9.5mm.
#806 Outer Left Side 9.9 Right Side 9.7 (hows that for taper)
#806 Inner Left Side 10.6 Right Side 11.2 (wow)
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 06-22-2003, 02:03 AM
Bill Verburg's Avatar
The pads can be worn down as much as you want, but be aware that the thinner they get the more heat in the fluid will be a problem. Personally for track use I would want to keep at least 50% new pad thickness(75% is even better).
The rotors have 2 wear limits
  • the symmetric wear limit is 1mm/side which leave 18mm remaining
  • for machining its 18.6mm which will allow .3mm of remaining wear per side
Bill Verburg
Old 06-22-2003, 07:30 AM
304065's Avatar
Muchos gracias Bill. Gives me a reason to try the new Pagid Black compound.
'81 R65
Old 06-22-2003, 08:28 AM
