-   -   How do you jack up the front? (http://forums.pelicanparts.com/porsche-911-technical-forum/1158044-how-do-you-jack-up-front.html)
mike sampsel 02-28-2024 08:39 AM
Originally Posted by Sajan (Post 12203219)
:) will try it out and see.
I got a second jack because for the rear, I don't know if there's an area like the front I can use to lift up the rear in one fell swoop. Don't want to lift up using the engine.
Hey, if Ivan says it's okay to use the engine, it's okay! (see Proporsche post above) A piece of cardboard between the jack and the engine might help distribute the weight point some.
proporsche 02-28-2024 09:37 AM
to lift the front is very easy to(as mentioned by Mike)...use the place in front of the fuel tank .It even work if you have the A/C condenser with the grille..
Ivan
http://forums.pelicanparts.com/uploa...1709143224.jpg
Hulley 02-28-2024 11:18 AM
Thanks everyone, we've got a great group here!
TimT 02-28-2024 11:57 AM
I use a hockey puck...
