ShakinJoe's Avatar
Lightbulb How To: Relocate Console Switch to Dashboard
Many of you have been watching my 87 Carrera "Jenny Craig" thread on weight loss.
438 lbs gone in 5 days - My Build Story
I wanted to post separately some items that might be useful, where you did not have to dig thru my boring thread to find it. One of them is the switch relocate that I could not find a ton of info on, so I decided to document it for the forum as I have received much more from this forum than I have contributed.
In short, I have removed things from my 911 that I do not use or...really need in effort to remove weight for HP and handling reasons. I will still drive it on the street sparingly, so it has to have the necessary switches and items needed for obvious reasons. Since I deep sixed my console; I need a place to put may Hazard Switch as I definately want to keep it. This thread can be used for any of the switches that might be relocated to the dash...but the Hazard and R Def are the hardest.
Enjoy............................................. ...............
'87 Carrera - 2400 lbs of Track Beast!!
'88 Carrera Cab - Too nice for the track.
'85 Targa - Salvage title that was not caught!
Old 08-20-2008, 03:49 PM
ShakinJoe's Avatar
PART TWO of SWITCH RELOCATE
Here is the remainder as there were too many pics!!!
NOW....you can do it too!!!
Old 08-20-2008, 03:53 PM
After the next project
x98boardwell's Avatar
Shakin Joe
Great Job, Very clean and well detailed post. Thanks
Old 08-20-2008, 04:21 PM
rfloz's Avatar
Nicely done DIY. These old eyes especially appreciate the large print version.
Question - If this is really going to be a lightweight car, why do I still see a cigarette lighter, ashtray and glove box cover? Ounces, man, ounces.
No, I'm not kidding. The first two are gone from mine, but getting the glove box cover out is making me nuts. You need to remove the passenger side lower dash pad and there are two, maybe three, screws you have to get from the backside of the dash. I can barely feel two of them and can't even figure out what size nut-driver I need. Feel free to do an illustrated DIY on that one anytime.
Bob F.
1984 Carrera Factory Turbo-Look
Old 08-20-2008, 04:46 PM
ShakinJoe's Avatar
rfloz,
Thanks for the reply. My build thread rambles about what lightweight means to me. It will still be used for street, but I just do not use the heat, AC, and a lot of other crap, so I took it out and weighed each and every piece! See my thread. 438 lbs gone in 5 days - My Build Story
But I am not done yet inside. I will take out the ashtray, and a few more things, but I cannot see getting more than 20 lbs out of the car from the inside stuff. My biggest weight now are windows...and I am not prepared to do that yet. Notice the word yet.
On the lower dash removal, there are three nuts (all 8mm) and one screw. It took me one hour to get it out the first time....now I can do it in 5 minutes. If there is enough response to this, I will do a thread on it. I did cheat a little and used a video inspection camera made by Testo to find the nuts.....absolutley incredible!
http://www.testo.us/online/abaxx-?$part=PORTAL.USA.Applications&$event=show-from-content&externalid=opencms:/Products/MeasurementParameters/ambientairquality/Messgeraete/318VPRO_JUST_USA/USEnglisch.product
Thanks for the positive comments.
Old 08-20-2008, 05:03 PM
Nice work Joe but I would have ripped that blank radio plate a new 'hole'..well a couple and mounted the switches there. You can also convert the air pump connections to clamps and use a direct connection to the battery when you need to pump, then you can remove the lighter. Of course, because you live in Florida you can remove the turn signals and the turn signal switch...sorry I couldn't resist.
Peace, Ron
www.ronorlando.net
78SC Targa 3.2 SS, 964 cams, CIS, SSI's,Dansk
Own a gun and you can rob a bank , own a bank and you can rob the world.
Old 08-20-2008, 05:57 PM
ShakinJoe's Avatar
Hey MTrain
I knew someone would go there...but it is so well deserved!! Too many driving styles on one road = recipe for lots of disasters. I left the blank alone as most users will still have their radio...and well, it was the easy way out and we cannot have that!!! Thanks for the reply!!
Old 08-20-2008, 06:26 PM
Everytime I visit a thought enters my mind...all the 16 year old drivers on drugs, all the seniors medicated and no one uses the turn signals...totally amazing driving situation. So I prefer a rental car. Your car looks great..be careful!
Peace, Ron
www.ronorlando.net
Old 08-20-2008, 07:17 PM
ShakinJoe's Avatar
You're forgettin' all the drivers from Jersey!!!!
Old 08-20-2008, 07:31 PM
dshepp806's Avatar
Good Work Shakin' Joe.
Best,
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 08-21-2008, 08:11 AM
rfloz's Avatar
Joe-
Thanks for the info. Using an old-tech long handled mirror, I found the 8 mm nuts, but not the screw.
Do you remember where that is located?
BTY, just so you know it's well worth it, the ashtray and cigarette lighter together weigh 10 oz. and that (usually) non-functional clock is 6 oz. Hey, that's a whole pound!
Bob F.
Old 08-22-2008, 09:31 AM
ShakinJoe's Avatar
Joe-
The screw is removed from the end panel (under vent) from outside. It should be visible. The mirror is good....this camera was awesome!
Clock is sold...and gone. An Atlanta Pelican convinced me that he needed it more than I did.....and he was right dawg gone it!! Ashtray to be removed upon return of car. I just want to make sure my neon under dash street light system is well hidden!! kidding of course
Old 08-22-2008, 08:37 PM
rfloz's Avatar
Thanks.
Keep the neon; it's eVaR so kEwL!
Bob F.
Old 08-24-2008, 08:44 AM
If you use the step bit right off the bat would the switch still stay in if you went all the way down to the 1 1/8” to get through the metal plate behind or do you need a hole saw for that part?
Old 08-05-2021, 10:46 AM
a.k.a. G-man
Geronimo '74's Avatar
good advice, after thirteen years...
Old 08-06-2021, 01:24 AM
82 911 SC - Ancora Imparo
This is pretty handy, thanks. I removed the console long ago and will be relocating the AC and fan switches to the dash. Good to know it’s about as straightforward as I envisioned.
Ethan
1982 911 SC - Wine Red Metallic Coupe
Old 01-16-2023, 10:51 AM
Mr. Merk's Avatar
Were you able to stretch the wiring up there or did you have to extend it?
Old 06-18-2023, 08:47 AM
I thought I had some charging problems so I got a USB charger with a voltage read out. I went over my grounds and charging problem went away. I was relocating the console switches so I might as well get a gauge for the volts as it looks better. This what I did.
1988 Carrera coupe
1966 250 Ducati
2015 VW Golf TDI gone because Dieselgate!
2021 VW Golf TSI
2014 Ninja 300
Old 06-18-2023, 10:23 AM
I ended up relocating my AC control switches to the dash, and it was a much bigger project than expected. I had to add a section of wiring harness and also fit the square AC thermostat switch into the round hole on the backside of the dash. But the end result was worth it. Now I can re-carpet the car and have a clean floor around my Wevo shifter.
Ethan
Old 06-20-2023, 10:09 AM
fallingat120mph's Avatar
Started the process today - waiting on the knock out bit (had to be ordered).
It was...very...nerve wracking to drill out the initial 1 inch hole. I did the 2 step approach as I felt comfortable with that. Will expand the hole slowly with the new bit.
Redoing the interior and center console delete so this came in handy. Will post a finished photo this weekend.
Erik
1986 911 Coupe
1986 911 Targa
Old 02-23-2024, 07:49 AM
