-   -   Graphite Additive to 911 engine & transmission question (http://forums.pelicanparts.com/porsche-911-technical-forum/115805-graphite-additive-911-engine-transmission-question.html)
Gunter 06-21-2003 08:24 AM
Porsche does not recommend additives but there is evidence that Graphite-based products like "Moly Lube" reduce friction. Has anyone used additives? JW or Wayne, what is your experience or opinion? Thanks. :)
island911 06-21-2003 09:34 AM
DON'T DO IT! . . .or even think about it.
Graphite is a fine DRY lubricant, but has no business being mixed in a motor oil.
k9handler 06-21-2003 09:59 AM
ditto
UTKarmann_Ghia 06-21-2003 11:16 AM
Early_S_Man recommended the Swepco 212 w/moly to me and it's been working great in my tranny for months. It's also multi-viscosity so it has a higher heat range.
Geary 06-22-2003 08:43 AM
Moly and graphite are different additives.
sammyg2 06-22-2003 10:35 AM
Graphite and teflon oil additives = snake oil. Molybdenum disulfide is a different story. I would not put it in my engine but in a trasnsmission where the gears need an extreme pressure grease I can see some benefit.
island911 06-22-2003 11:07 AM
Apparently there is a concoction called "G-M lube" or "Graphite - Moly Lube" . . ..a mix of graphite with molybdenum disulfide.
It's said to be "thee thing" in lubricants, for Pinewood cars.
So, obviously, it must make 911's faster too.:rolleyes:
Steve W 06-22-2003 12:39 PM
Do a search on Dow Corning's Molykote M Gear additive, fantastic stuff, and I use it in all my transmissions.
http://www.dowcorning.com/applications/Product_Finder/PF_details.asp?l1=003&prod=01005855&type=PROD&pg=0 0001044
http://forums.pelicanparts.com/porsche-911-technical-forum/103650-moly-vs-not-gear-oil-question.html
Gunter 06-22-2003 05:10 PM
Thanks for the input. It seems that "Moly" in transmissions is o.k. but people stay away from any additives in the engine. Sounds good to me. SmileWavy
RoninLB 06-22-2003 06:26 PM
in the 60s/early 70s street racing scene some kind of GM rear end additive was very much respected by the big block guys.........Ron
Geary 06-23-2003 08:21 AM
Moly is of course absolutely essential for proper camshaft break-in. There's no need for it in the engine after this initial period.
