Somatic Negative Optimist
Porsche does not recommend additives but there is evidence that Graphite-based products like "Moly Lube" reduce friction. Has anyone used additives? JW or Wayne, what is your experience or opinion? Thanks.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD! 1995 seafoam-green 993 C2, LSD, Sport seats. ![]() Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Information Junky
DON'T DO IT! . . .or even think about it.
Graphite is a fine DRY lubricant, but has no business being mixed in a motor oil.
Everyone you meet knows something you don't. - - - and a whole bunch of crap that is wrong. Disclaimer: the above was 2¢ worth. More information is available as my professional opinion, which is provided for an exorbitant fee.
Montana 911
ditto
H.D. Smith 2009 997.2 S 3.8 PDK 2019 Ford Ranger Lariat FX4 Baby Raptor 2019 Can Am Renegade 1000R XC 2020 Yamaha YFZ450R |
Early_S_Man recommended the Swepco 212 w/moly to me and it's been working great in my tranny for months. It's also multi-viscosity so it has a higher heat range.
Matt '82 911SC Targa! |
Moly and graphite are different additives.
Unregistered
Graphite and teflon oil additives = snake oil. Molybdenum disulfide is a different story. I would not put it in my engine but in a trasnsmission where the gears need an extreme pressure grease I can see some benefit.
Information Junky
Apparently there is a concoction called "G-M lube" or "Graphite - Moly Lube" . . ..a mix of graphite with molybdenum disulfide.
It's said to be "thee thing" in lubricants, for Pinewood cars. So, obviously, it must make 911's faster too.
Do a search on Dow Corning's Molykote M Gear additive, fantastic stuff, and I use it in all my transmissions.
http://www.dowcorning.com/applications/Product_Finder/PF_details.asp?l1=003&prod=01005855&type=PROD&pg=00001044 Moly vs. not...Gear oil question Last edited by Steve W; 06-22-2003 at 12:45 PM.. |
Thanks for the input. It seems that "Moly" in transmissions is o.k. but people stay away from any additives in the engine. Sounds good to me.
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
Moly is of course absolutely essential for proper camshaft break-in. There's no need for it in the engine after this initial period.
