Why is the 915 coupler adjustment so sensitive?
So Why is the 915 coupler adjustment so sensitive?
The shifter itself is not gated, its just a wide open box that only limits travel on the extreme ends. The only critical issue as far as the shift lever is concerned is lining up the 5th gear and reverse lock out tab with the same location on the transmission. the rest of the travel is an open for the most part unrestricted box.
So the coupler and lever are free to move where ever the lever wants to move within the confines of the shift level tower. As long as you don't hit the edge of the shift lever box before the transmission hits the end point the exact location should not matter much.
So if the shifter is up against the corner of the shift tower , with a mm gap so it doesn't hit the edge, and the coupler is turned against the stops for that gear, then why is there any issue with coupler alignment?
Is it really an alignment issue or is it the fact that things move when we go to tighten them?
Does the issue just come down to that fact that it takes 4 hands to do this properly and we only use 2? Do we really just need a couple of fixtures that hold the shift lever in place and holds the coupler in place while we tighten that dam bolt?
Just curious.
Old 03-28-2024, 10:28 AM
It is all due to the shift lever being fairly tall and rotating the shaft from just a little movement.
Just center the forward and back about equal distance in either way. If you don't have a helper, tie the shifter over to extreme left with a bungee cord to the steering wheel, and rotate the coupler to the right as far as it will go with finger pressure, and tighten the set screw. Done.
Take a test drive. Enjoy.
Old 03-28-2024, 02:08 PM
Schulisco's Avatar
No, it's far more a matter of feel for the individual gearbox and shift linkage.
Considering the shift linkage and the gearbox is good or even overhauled, the correct gea box oil is filled, then the best way to adjust the shift lever / shift linkage is tp go on a tour with some tools for adjustment. The gearbox shifts best when gearbox oil is warmed up. Do not adjust it when gearbox oil is cold! Thsi requires to drive at least 15-20mls, then stop, adjust the linkage at the coupler, test it, tighten it, and go on. Repat this several times on that trip unitil you found the perfect adjustment.
Be careful not to engage two gears at the same time which happens accidentially sometimes.
Here's a detailed description to overhaul the linkage and a short overview on how to adjust:
https://rb.gy/69gy9i
And here are some videos:
https://www.youtube.com/watch?v=tEdOeHUYjU0
https://www.youtube.com/watch?v=b3nPONBAaZM
Thomas
1981 911 SC Coupé, platinum met. (former tin (zinc) metallic), Bilstein shocks, 915/61,930/16,WebCam20/21, Dansk 92.502SD,123ignition distributor with Permatune box as amplifier,Seine Systems Gate Shift Kit,Momo Prototipo. Want to get in touch with former owners of the car. Last registration in US was in 2013 in Lincolnshire/lL.
Old 03-28-2024, 02:37 PM
proporsche's Avatar
Thomas
bronze bushings on shift coupler plus as he said zero play..= bad idea....
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 03-28-2024, 03:39 PM
Schulisco's Avatar
Ivan
I have bronze bushings on my SC... No issues at all.
But I have to admit that a single bronze bushing was too narrow and I had to widen it half a millimeter up to mount it...
Old 03-28-2024, 03:52 PM
PCA Member since 1988
...and you have to lubricate the bronze bushings occasionally. The plastic ones work dry.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 03-28-2024, 04:55 PM
And short shifters make the perfect adjustment harder to nail.
206 637 4071
Old 03-28-2024, 05:14 PM
