				Through Body sway bar "bushing"
			Not sure if it is technically a bushing or what you'd call it. But I took apart my sway bar to clean up before reinstalling and the part that bolts to the body with 3 bolts has a plastic 2-piece bushing on each side. Mine came out very brittle and one broke. What would these be called and where can I find replacements? Is a newer version available? Thanks for any info! Mind you this car is a 1968
			Porsche calls it a "anti-roll bar bearing bracket" in the catalog. Be aware that Porsche offered front bars in 11, 13, 15, 14 and 16mm thickness.
			Most are either 911S 15mm bar bushing 901 343 792 02 or USA 911/912 13mm bar bushing 901 343 792 01
			SWB 912 - G50 Carrera - 986 Boxster - 997.2 911 Turbo - 958.2 Cayenne - 9Y3 Cayenne GTS SOLD: 958 Cayenne Turbo S - 997 Carrera 4S - 957 Cayenne Turbo Workshop Coordinator at Ehrlich Motorwerks instagram.com/patrickossenkop ehrlichmotorwerks.com Last edited by Mr. Merk; 03-08-2024 at 12:24 PM..  |
			The factory never installed plastic bushings on production cars. Are you sure that the ones in you car aren't just hardened rubber? Also the '76-'77 Turbos had an 18mm thru the body sway bar, so add that number to the list that Mr. Merk provided.
	Ed 1973.5 T  |
			Indeed! You need to use a caliper to measure the diameter because there are mutliple options for #29 and the catalog doesn't tell you what size each part number is
	SWB 912 - G50 Carrera - 986 Boxster - 997.2 911 Turbo - 958.2 Cayenne - 9Y3 Cayenne GTS SOLD: 958 Cayenne Turbo S - 997 Carrera 4S - 957 Cayenne Turbo Workshop Coordinator at Ehrlich Motorwerks instagram.com/patrickossenkop ehrlichmotorwerks.com  |
			Now that I cleaned these up, they look to be 2 piece 3D printed bushings!
			 Wingnut
			This is what my '73.5 looked like during restoration, the bushings were rubber...
	Tom There's a hole in my garage where the money goes...  |
