Help identifying a part
While replacing my driver’s side injectors on our new to us ‘84 3.2 I noticed a crumbing sensor or plastic wire housing of some sort. You can see a bit of a green wire but it connects to a black wire that, with a red and white wire route down through the tin. Here’s a a couple of pictures with the item circled.
I’m struggling to even describe it well enough to search. Thanks in advance for your help.
Old 03-23-2024, 03:16 PM
PCA Member since 1988
Pics didn't post.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 03-25-2024, 02:27 PM
proporsche's Avatar
go to bottom "go advance" and there is a blue link to insert pic
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 03-25-2024, 03:38 PM
Possibly the O2 sensor connector, which from heat typically crumbles.
Dave
Old 03-25-2024, 03:48 PM
MBAtarga's Avatar
Yep - got to be it!
Mark
'83 SC Targa - since 5/5/2001
Old 03-25-2024, 06:25 PM
Thanks Very much for the advice! Yes, does seem to be the O2 sensor housing/ connector that has crumbled into a yellow mess. I'll work opn the picture posting as well. Sorry about that.
Old 03-27-2024, 06:05 AM
Does it look like this? If so, two of them are position sensors and they crumble too. Kind of a pain to replace just dont mix them up!
Old 03-27-2024, 07:05 AM
Nail polish on one of the gray sets so you know where it goes to.
Not marked, no start, switch connectors. Both same sensors that do different things.
A real pain to change in the car. Bosch BMW sensor work and half price, get reference to order.
Bruce
Old 03-27-2024, 02:54 PM
Bruce
There is a little yellow tag on the sensor side and the harness side that id's them, but it could be long gone. I made a couple of notes as to how they were. You are right it is a pain to swap them but possible. I recall a grommet that I fought hard to get back in place properly.
Old 03-27-2024, 03:11 PM
As a reminder so you never forget it, both flywheel sensors are cross-connected on the vertical ramp. Meaning the lower sensor on the flywheel goes to second higher position on ramp, and vice versa.
And of course the highest position on ramp is for the CHT sensor (white connector).
Gilles
RoW 88 Carrera coupé
Old 03-28-2024, 02:15 AM
