Home of the Whopper
Filling tranny with fluid
Not sure if this link works...
But genius level idea.
Makes filling the tranny pretty easy.
https://www.facebook.com/reel/1972428413158273?mibextid=9drbnH
“The wave is not the water. The water merely told us about the wave moving by” – Buckminster Fuller
Old 11-17-2023, 05:41 AM
The link works.
Great cheap tool idea.
Old 11-17-2023, 06:38 AM
proporsche's Avatar
not bad at all..if i do it ,i use gravity through the left wheel fender(under it of course)
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 11-17-2023, 06:53 AM
Wrighteous's Avatar
Very cool! Swepco is pretty thick... maybe if you leave the container out in the sun for an hour or two, it'd behave like that.
I've used a simple hand pump. It sucks, a friend makes it easier, but it's doable!
Old 11-17-2023, 09:53 AM
PCA Member since 1988
Nah, that's not real life. Using compressed air iattached to a water bottle? I guarantee you will end up making a mess. Instead, I use an old style pump oil can, and the rest of the time it sits on my workbench getting used as... wait for it... An oil can. Gear oil is a pretty good general purpose oil lube. When building an engine, I use the same gear oil can for assembly lube (but not for break in cam lube). One can for multiple uses reduces clutter on the workbench.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 11-17-2023, 12:23 PM
proporsche's Avatar
here is a pic how i do it ..no mess and easy job..
Old 11-17-2023, 01:39 PM
gearhead
WHAT? No way. FFS…
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 11-17-2023, 03:34 PM
DWeg1998's Avatar
I do it on my back under jack stands with a cheap Harbor Freight pump that shoots the hoses off when pumped hard and knocking over bottles with my elbows squirming around on the ground cussing and the garage smelling like gear oil for a couple months.
Old 11-17-2023, 03:35 PM
RDM RDM is offline
Coram Deo
RDM's Avatar
I do it Ivan's way. And I put the gear oil in a bucket of hot water beforehand. The oil doesn't have to be that hot to pour easily.
Did a Mercedes rear end last night. No trouble at all, unless your assistant doesn't measure well and overfills....
Dru
1980 911SC Targa • Petrol Blue Metallic • Cork special leather • Sport Seats • Limited Slip • 964 Cams • SSIs • Rennshifter
• 1990 250D Opawagen • 1995 E220T Sportline Familienwagen • 1971 280SE Beverly... hills that is • 1971 Berlina 1750 Faggio
Old 11-17-2023, 05:09 PM
I just use one of those cheap hand pumps that goes on a qt bottle. Not fun but works. Cordless grease gun......now thats the bomb, and makes greasing fun. Dewalt needs to make a cordless gear oil pump!
Old 11-17-2023, 06:00 PM
I use a cheap clicky clack fuel pump its the cleanest easiest method iv come up with sofar. I have 3 old jeeps so I do alot of rolling on the floor with gear oil.
Old 11-17-2023, 07:13 PM
Bill Douglas's Avatar
Yup, that's the way I do it. No need to get too fancy, it's only oil.
Old 11-17-2023, 08:33 PM
HarryD's Avatar
Gravity is your friend (plus a ladder):
Originally Posted by HarryD View Post
Nice but your funnel support is WAY too complicated. Just about all of us have a 6 foot or so step ladder so we can just do what Jadams1 did.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 11-17-2023, 09:42 PM
I've used that method but with a big bottle and made proper fittings with a tube that slides over the air gun nozzle. Gravity works but it's fun to make tools.
Old 11-18-2023, 06:40 AM
Registered Minimalist
75 911s's Avatar
Hand pump. Simple and you can do it under the transaxle. You can control the flow in until it's just seeping out the of the top hole.
Duane / IG: @duanewik / Youtube Channel: Wik's Garage
Check out my 75 and 77 911S build threads
Old 11-18-2023, 07:45 AM
Gravity works and it's free.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 11-19-2023, 06:42 AM
This is actually the procedure from the factory service manual.
1982 911SC
Old 11-20-2023, 06:39 AM
Yep,
Did mine in a similar way recently!
Have to say, going on the title of this thread, I was half expecting to see a man in a dress drinking a pint!
"But instinct is something which transcends Knowledge
We have undoubtedly certain finer fibres that enable us to perceive truths when logical deduction or any other wilful effort of the brain is futile"
Nikola Tesla
Old 11-20-2023, 07:22 AM
MBAtarga's Avatar
The facebook link now appears broken.
Can anyone chime in on just what it instructed?
Mark
'83 SC Targa - since 5/5/2001
Old 11-20-2023, 02:27 PM
They put the fluid in a plastic bottle with a hole in the cap that the hose fit tightly and to the bottom of the jug. Then stuck an air blow gun in another small hole and pressurized it to blow the fluid up the hose
Old 11-20-2023, 02:49 PM
