-   -   Window keeps sticking (http://forums.pelicanparts.com/porsche-911-technical-forum/1159570-window-keeps-sticking.html)
autojack 03-28-2024 11:50 PM
One of my power windows got stuck in the closed position some time ago. I eventually took the door panel apart and got it unstuck using the manual hex key in the motor trick. I only had to turn it slightly, it gave a pop, and then worked normally using the motor. I greased everything I could get to, and then put everything back together. No issues for a few weeks, but I went for a drive last weekend and... It's stuck again. Should I just replace the motor at this point? I'm surprised it stuck again, because it worked smoothly with no hesitation after I freed it up last time.
Bill Douglas 03-29-2024 12:31 AM
Maybe spay some silicon on the window track so the glass slides up and down without as much friction.
