Sunroof Wind Deflector Installation - help required
Having purchased a replacement kit, made of metal so expensive that the car's value has just doubled, I'm loath to attempt installation without any instructions or guidance. I've search the web and can't find anything showing the process from end to end. The kit is one of those Golde replacements (3 deflector pieces, 4 hinges and 2 springs) going on a SC. Any help would be greatly appreciated. Cheers
Old 07-03-2020, 02:03 PM
wareaglescott's Avatar
Took my entire car apart down to bare shell. 79 SC. The wind deflector simply screwed out and came out piece by piece. Don’t recall anything tricky at all about taking it in or out. Did also replace the felt pieces that were under it. You may want to have those on hand as well.
Old 07-04-2020, 04:55 AM
Thanks for the reply. Did you dismantle the deflector; hinges taken off spring? I have new springs and new hinges. It's the install of those bits that I'm concerned about. Cheers
Old 07-04-2020, 09:08 PM
filoudebruxelle's Avatar
@Choc Mousse I am facing the same issue, albeit I haven't purchased the gold wind deflector. Gold by invoice, aluminium by material. I feel your pain. :-) I found two suppliers here in Europe: https://nl.parts-wise.com/90156470399-911-(65-82)-complete-reparatieset-voor-de-windspoiler-van-het-schuifdak,-deze-set-bestaat-uit-de-3-spoilerdelen,-2-open-en-2-gesloten-scharnieren-en-2-veren./p247076/ and https://www.vankesselsportscars.com/interieur/interieur/schuifdak/90156407301-schuifdak-deflector-reparatieset.htm
Have you found a more economic source, would love to hear about it.
Were you able to mount it correctly? Would you like to share the procedure?
Many thanks for sharing.
Filip
Brussels
1978 911SC
https://www.instagram.com/that911man/
Old 04-06-2022, 03:28 AM
This video will show you everything you need to know, in far greater detail than you'll find anywhere else. It's a three part video, I've pasted a link to part one, the others are linked from the first.
I did a full sunroof rebuild so all of it was relevant for me. It's possible you only need to follow some of the steps. Lastly, while my car is a 1984 and has a slightly different design than the earlier model, the parts are identical enough to do what you need
https://www.youtube.com/watch?v=5TD-DeF2jTg
Old 04-06-2022, 05:28 AM
Hi Choc Mousse, don't know of you are still on here but did you ever manage to installer the kit ? I spent a few hours wrestling with one at the weekend and thought I better see if there are any instructions out there ! If you got it fitted, any tips about the springs going through the clips ?
Old 08-21-2024, 01:23 PM
Tags
911 sc , deflector , sunroof
