85 911 brake fluid change
any benefit or not recommended to using synthetic brake fluid? this is the first time flushing this myself. what is recommended for my 1985 carrera? what do
you like? how much fluid is needed for a full flush? thanks!! Last edited by jgurnari; 04-08-2024 at 08:31 AM.. |
I use Pentosin DOT4. One liter should suffice.
1987 911 Carrera coupe - Guards Red 2010 997.2 C4S 6-Speed 2005 Mini Cooper Convertible (R52) - Wife's car 1977 VW Bay Window Camper Bus |
I see there are few, any specific Pentosin DOT4
Basically like on many other cars too. Just one hint: My SC has got a overflow at the brake fluid reservoir going into a rubber hose and finally a steel pipe to drain brake fluid under the car. Don't know if your car this also has. If so, then you have to shut this line with a clamp before. Otherwise you're going to bleed the pipe and not the brake...
![]() Exact amount is unknown, depends on how old and worn your brake fluid is and how much fluid you need to flush the system. The 85 Carrera still has the 915 and cable operated clutch, so no additional brake fluid necessary. I suppose 1 liter / 1 qt should be enough. Outr host made a manual: https://www.pelicanparts.com/techarticles/101_Projects_Porsche_911/49-Bleeding_Brakes/49-Bleeding_Brakes.htm No videos found yet for the SC & Carreras yet. I recommend to use a brake power bleeder instead of pumping the fluid with the brake itself. They don't cost that much and the change is an easy job then. ^ ![]() Make sure that you also got the right adaptor to connect the bleeder with the reservoir, I got an original from ATE. Works like a dream. ![]() https://www.ate-info.de/de/details/produkte/adapter/bleeding-unit-adapter---20 There may be others available too. I prefer that high quality machined aluminium ones. The china plastic crap is not worth the money. DOT5 is not recommended for street use. The problem with that: A single drop of water may poisons it and makes it completely unsuable then. Go with DOT4 and replace it regularly every 2 years. DOT 5.1 is also usable for street use as it is also made from glycol and not from silicone as the DOT 5 is. I personally measure the water content of the brake fluid regurlarly with an electronic brake fluid tester. After three years I'll replace the brake fluid for sure, no matter how high the water content is. Depends on the driving conditions and mileage. Security is not negotionable! Thomas
1981 911 SC Coupι, platinum met. (former tin (zinc) metallic), Bilstein shocks, 915/61,930/16,WebCam20/21, Dansk 92.502SD,123ignition distributor with Permatune box as amplifier,Seine Systems Gate Shift Kit,Momo Prototipo. Want to get in touch with former owners of the car. Last registration in US was in 2013 in Lincolnshire/lL. Last edited by Schulisco; 04-08-2024 at 10:45 AM.. |
I know of 2 - "conventional" Pentosin DOT4 and Pentosin DOT4 Low Viscosity (LV).
The first one is fine.
all you need is one can of dot 4 br.fluid
You can just do it yourself,get a jar-from pickle make a hole on top get clear hose which you attach to the caliber niple and the other end into the jar-where you can just put a little br.fluid so the hose is dipped in it. Start with right rear after left rear next right front and last is left front. Open the nipple and pump the pedal about 3-4 times go close the niple and repeat on left ....Alway refill the reservoir after each 3-4 pumping.... It helps if you have your wife or friend to pump but it is easy doable yourself. No need extra tools and e.t.c. plus quality time with your 911 always counts... Been doing it like this since ever ......oldtimers way;-))) Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
yes same
yes i do have the same overflow at the brake fluid reservoir
found this one at Napa Auto
I use Prestone DOT 3 synthetic. I have no need for anything fancier.
Just about all brake fluids are now labeled as synthetic. The only one to avoid is DOT5. Glycol-based brake fluids are DOT3, DOT4, Super DOT4 and DOT5.1. The one to avoid is DOT5. It is silicon-based brake. This does not work well in most situations. I believe DOT 3 could be a better choice for a daily driver. Dot 3 has a slightly lower boiling point than 4, but is less hygroscopic. Unless you get the brakes really hot, DOT 3 will last longer and absorb less water than the others.
Ed 1973.5 T |
I have used the ATE Type 200 for 29 years. I change my fluid each and every spring. I still have the original master cylinder and no brake issues.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
but nice idea..not for me but for next bleed job person;-) Ivan
Still here
The LV stuff, isn't that more suitable for modern ABS systems ?
It's a 914 ...
I had a terrible time with speed bleeders. They kept sucking air into the calipers, presumably via the threads. Tossed 'em and went back to regular.
I used a MIghty Vac. Works great there is a video put online by MV about how to use it for brake bleeding. Very easy to do by yourself. Just add a bit of fluid every couple of minutes to keep the reservoir from going empty.
Same MC as when I got the car 20+ years ago. Replaced the front calipers last year (PMB) because the dust seals looked funny. Brakes were working fine. I have done 8+ autocrosses since I got the car and in the last 4 years about 8 HPDEs each year. Never boiled fluid or had brake fade with stock ATE M calipers in a 2500 lb car.
![]() I prefer a vacuum pump. I put my car on my lift, remove all the wheels. I suck the old fluid out of the reservoir, then fill it with fresh fluid. Then start at the right rear, and suck the longest to get the fluid through the system. The left rear, right front, and finally the front left. Put the wheels on, lower the car all the way, and torque the lugs. One step I learned long ago, I put my torque wrench on the floor of the driver's seat. Impossible to forget to torque the wheels that way.
Still here
Oh, one more thing, surprised no one has mentioned this .... watch the paint ... everywhere.
Don't touch anything painted, try not to, do your best, while there's BF on your hands. |
Since I do not have a lift, its pretty much one wheel at a time. I hand start the lug nuts, thenuse my air impact wrench to tighten to about 80 ft-lbs and finish with my torque wrench.
And yea, I drape a fender cover over the left front fender to be 100% sure no brake fluid his the paint. And a small towel around the brake reservoir. And I wash my hands a lot. The bubbles in the line never bother me. It is from the not perfect seal from the hose to the bleeder. Just tighten the bleeder before removing the hose. I have a perfect feel on the pedal.
| Tags |
| brake fluid , brakes |
