911SC '82
Question Rennline roof rack, im the only one with this issues?
I juts got the Rennline Roof Rack thanks to the recent holidays discounts...
but I'm baffled by the fact the wood slats seem a bit loose... I havent install it on the car yet, but im afraid with vibration they may snap out because they are not tight enough inside their slots... they seem shorter of what they should be to fit snuggly
does anyone had issue with it?
Old 12-03-2024, 11:38 AM
I've had the Rennline rack on my 911 for about two years. No issues. My slats need to be bent up about a 1/2 inch to inch before they can be removed.
Old 12-03-2024, 03:00 PM
I'm good with tools.
AG81's Avatar
I was one of the first owners of the Rennline rack. Over three years zero issues.
72 911 Coupe "OILDOOR"
24 INEOS Grenadier (daily)
02 996 4S (owned since new - heavily optioned)
Old 12-03-2024, 04:21 PM
fitchn's Avatar
Ditto for me, no issues at all with the slats. In fact, I found that they had to be bent quite aggressively to get them to slot in/out. The rack is great, I even figured out how to get a couple of bikes mounts on there. I've never gotten as many thumbs up as when a bike is up top.
Noah
79 SC
minerva blue metallic
Eureka CA / Boulder CO
Physics is like sex, yes there are some practical applications, but that's not why we do it.
Old 12-04-2024, 06:28 PM
Got mine today, yeah there’s some play in the slats side to side but they are def not coming out, put a dap of silicone on the tip if you want to dampen that.
Idk why, but I thought the feet were rubber coated, trying to find something now to protect the paint that isn’t permanently on the car, ideas?
Old 12-09-2024, 04:00 PM
Full Send Society
McMaster sells rubber trim in various colors.
I used this on my homemade roof rack to protect the paint
Food Industry Rubber Trim, 1/8" Wide x 15/32" High Inside
https://www.mcmaster.com/7475N16
-Julian
1977 911 S: Backdate, EFI/ITB, AC project in the works:
http://forums.pelicanparts.com/porsche-911-technical-forum/1106768-when-well-enough-cant-left-alone-backdate-efi-itb-ac-more.html
Old 12-09-2024, 04:49 PM
TastyReuben - I had PPF put on my rain gutters and slightly up the roof to protect the paint from the feet.
Old 12-09-2024, 05:10 PM
911SC '82
cool..., i ended up using some rubber gloves and cutting the fingers and using the rubber to add a bit of tightness...
I'm also thinking of wrapping them completely with some heat-shrink black tubes so I can have them in black without using coloring stains etc
Old 12-16-2024, 11:56 AM
