Is it possible to adjust wipers arm so they park a bit lower
Is it possible to adjust wipers arms so they park a bit lower on the windshield?
I kinda hate the wipers on the drivers side, but I also read about some drawbacks of reversing them. my main simple need would be if to have them reset/park a bit lower. right now I need to push them with my hand. but when they run, the paring position is an inch or two too high. is not a problem or a defect per see... just my preference I guess wonder if they can be slightly adjusted (without bending them ;) |
Loosen the retaining nuts, wiggle the arms to free them from the post, reposition and tighten the nuts.
Before you start put a towel or cloth on your hood area underneath the wipers. That way when they unstick from the wiper motor post they don’t land on your hood (frunk) paint.
Also check that nobody previously swopped the left and right wiper arms. That also makes quite a difference.
Yeah, straight one on the outside.
thanks all good recommendations!!
or below the trunk/blower at the motor(a bit of pain) thanks |
On the arm. Loosen the nut a turn or so, lift the arm and wiggle it back and forth.
perfect thanks!
update: i was able today to remove the arm ( you need to remove it because there are splines that hold it) and reinstall it a little bit lower to my preference.
now I don't need to reverse it. they stay put very low thanks! hope it helps someone else |
What were some of the drawbacks you heard about reversing them? I was planning on doing this, so I’m curious Sent from my iPhone using Tapatalk |
Ivan |
Thanks!
10 mm nut ( if I remember correctly) just make sure you torque it down good so your wipers don't fly off at high speed during a downpour
The biggest issue I saw was that; with the wipers parked on the right, the final stroke before parking pushes the excess water to the bottom of the window. as the air flows up across the car it will push that water against the wiper blade which stops it from streaking up the window (when parked o the right, that's the passenger side). the water when blown against the wiper then flows out past the end of the wiper blade and streaks up the window in front of the driver. this isn't a problem as long as the wipers are running, but as soon as you turn them off the streak will be recreated by the water pushed up from the bottom of the window. so even in very light rain where you may want a single or intermittent wiper, the small amount of water from the window is concentrated at the bottom only to reform streaking directly in the view of the driver. |
^^^^this
I would guess that's why Porsche designed them to park on the driver's side--even on RHD cars.
| All times are GMT -8. The time now is 11:06 PM. |
