3.6 Wiring loom - a serious warning.
I had been having a bit of bother with my 3.6 conversion, some electrical wierdness. I understand the engine loom was recalled for incidences of fire and of self starting. Diagnosis made me wonder about a short in the loom......
![]() My engine is 64/05.
Running a 95 993 motor in an SC.... |
Ben, this wiring issue is well-covered in my book, The Used 911 Story, 8th Edition! It's a big problem with very expensive consequences! Thanks for posting!
Keep the Shiny Side UP! Pete Z. |
Platinum Member
Porsche Service Action Notification #W301
I believe someone posted about trying to get the recall done on an engine/conversion, so try a search, but I assume a dealer will want the engine in the car with the proper vin#. Maybe they will supply the part? Do you happen to have the VIN# of the car the engine came from? |
Can someone give us a thumb-nail summary of the problem?
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
Wiring loom is shagged.
As I understand there was a quality issue with looms from a particular factory, it was subject to a recall and replacements are available.
Common early 993 problem. You can get a replacement harness for $100. In an actual 993, it's a recall which the dealer should fix for free.
replacement wiring harness is ~$700. Was covered in my 96 993- but I had to pay for the labor to replace. My harness was as pictured above- really bad.
Chuck ------- 70 & 75 911S 96 993 C4S '10 F-150 |
Love to know where the wires in these harnesses were made.
I've never seen insulation fall apart like that.
Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey |
Apparently its not $100 anymore, its, gulp, £511, about 700 dollars.
Did you ask for this part number? 000.043.204.61
Platinum Member
Very informative and interesting. Pelican sells it for $99, just enter the part number in the upper left corner, or click here: Pelican Parts - Product Information: OEM-00004320461
Senior Member
Was this only a 993 and not a 964 issue? I have a 1992 964 engine in mine is why I asked.
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
Ah, very interesting, no, I asked for 993.607.016.14, as per PET, they are shut now, I'll call them back tomorrow.
Thanks. If that pn is $100 I'll do that. I have just got it out of the car, turns out the damage is only to the wires in the area at the back of the alternator before it passes through the shroud. Replacing 3 wires and a bit of loom tape and it could be an easy fix.
Softeners from the insulation don't like the heat from the engine. It's fine as long as the engine and fan are running but it gets very hot there once you shut down. Then it cooks the softeners out of the plastic......
Ingo
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430 I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!! How about a NoBadDays DualChip for 964 or '95 993 |
"Softeners from the insulation don't like the heat from the engine. It's fine as long as the engine and fan are running but it gets very hot there once you shut down. Then it cooks the softeners out of the plastic......"
Ahh ..... and that sort of service usage wasn't envisioned, known or spec'd by Porsche so the appropriate insulation grade of plastics was used?....more electrical idiocy from Porsche then, if this is your perception of the problem, which then goes beyond simply a faulty piece from a manufacturer.
I think of it as a communication problem. At some point one of the manufacturers has used a wrong-grade wire to build the harness. Happens all the time when you change suppliers.....
OK- this makes no sense to me. Perhaps last year that part number was for a complete harness, and now it is superceded as a repair kit. Would explain the price difference. Not sure what you get with a repair kit @ $100. The complete harness I got last year was just that--a complete replacement harness down to the last plug and fitting.
Order the harness and you pay $$$. Order the repair kit and you get the harness for 90% less. |
It's not isolated to the 993s. The last three 964s that came through the shop for rebuilds all had the same problem. Highlight photos:
Chris Carroll TurboKraft, Inc. Tel. 480.969.0911 email: info@turbokraft.com http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft |
Here is a discussion on Rennlist regarding the harness part number.
Engine wiring harness - Rennlist Discussion Forums Here is the actual document on how to swap it out. http://www.pcarworkshop.com/images/c/c9/Engine_wiring_harness_9752_2002_6tu901a02us.pdf |
