CV Joint Roll Pin Question
According to the PP parts drawing, there are two roll pins per CV joint. I cleaned the joint but cannot find any inside. Where are these pins supposed to be and what is their function? Thanks SmileWavy
The earlier joints used 4 bolts and 2 roll pins at the flanges to connect to the stub axle and the transmission, the later joints use 6 bolts. If you gave the year of your car we could tell you which joint you should have.
Good luck, Jerry M '78 SC |
I'm assuming he has an 80 SC, as his signature says, so his CV joints don't have roll pins.
Jerry M '78 SC |
| All times are GMT -8. The time now is 09:01 PM. |
