-   -   Shift coupler bushing issues / 3rd set (http://forums.pelicanparts.com/porsche-911-technical-forum/1160832-shift-coupler-bushing-issues-3rd-set.html)
jimtweet 04-25-2024 08:58 AM
This is now the third set of “genuine porsche” bushings I have ordered where the hole is oval. Is there a bad run of bushings or am I missing something? I order some aftermarket junk and they come in perfectly round and tight
http://forums.pelicanparts.com/uploa...1714060620.jpg
john walker's workshop 04-25-2024 09:25 AM
They're all oval. Parts Klassic sells the round hole ones, if they're in stock. Late 914s used the round hole. FVD probably has them.
Ian Comerford 04-25-2024 09:32 AM
I’m pretty sure they are oval so that a certain amount of NVH doesn’t get through the linkage and into the cabin. I fitted a Stomski coupler a couple of years ago and get all sorts of noise coming through now. It’s really noticeable on road trips so I am going back to the original design.
ErrorMargin 04-25-2024 09:42 AM
I went with brass bushings for the shift coupler. Much more precise than stock, but no extra noise.
https://www.pelicanparts.com/More_Info/RENTR18.htm?pn=REN-TR18&bc=c&q=brass%20shift
pmax 04-25-2024 10:26 AM
That fit looks way worse than normal even for these oval bushings.
http://forums.pelicanparts.com/uploa...1714066088.jpg
jimtweet 04-25-2024 10:31 AM
I can’t tell you how many of these couplers I have done over the years and this is the first I’m seeing this. I have never seen a oval or gap like this
pmax 04-25-2024 01:16 PM
As always, what JW said.
The factory bushings has always been like that.
Here's a set I had for years ...
http://forums.pelicanparts.com/uploa...1714076144.jpg
dtwa 04-25-2024 02:13 PM
I put these round hole, delrin bushings in my 85 last year. A little more compliant than brass. No slack, but no noticeable NVH either. Very happy with them. —Dave
https://www.rauchandspiegel.com/product/shift-coupler-bushing-delrin-round-hole/
MBAtarga 04-25-2024 03:03 PM
I learned something today.
NVH stands for Noise, Vibration, Harshness
I had no clue what you guys were referring to above.
boyt911sc 04-25-2024 04:12 PM
Me Too…………
Thanks for deciphering the NVH acronym. I had no idea what they stood for until you posted.
Tony
Rsnellie 04-25-2024 04:18 PM
Curious if it is corrected by installing it in the coupler…
jimtweet 04-25-2024 04:25 PM
I tried there was no difference. I really have never noticed a gap/play like this in anyone I’ve done before. I would consider this excessive. I’m not expecting push tight fit, but this seems crazy
PeteKz 04-25-2024 05:00 PM
When you compress that bushing into the yoke, it will tighten up.
eastbay 04-25-2024 08:22 PM
As everyone has said, factory is sloppy, aftermarket tight.
Schulisco 04-26-2024 02:42 AM
Jim, I do not get what's the matter with the bushings? Why do you replace them? Shifting problems?
Thomas
proporsche 04-26-2024 02:55 PM
yup the bushing will become rounder once it installed
Just for comparison.here is an original factory and it is owal....
Ivan
http://forums.pelicanparts.com/uploa...1714168393.jpg
ahh911 04-26-2024 03:49 PM
I took the aftermarket "round" one and oval'd it out just very slightly, figured Porsche had a reason. It shifts fine.
Phil
timc 09-22-2024 10:01 AM
Getting ready to do the Shift Coupler, and Shift bushings. Does anyone know the pro/con of the following bushings for the Coupler:
Brass, Delrin, Powerflex, or OE/OEM?
mepstein 09-22-2024 12:32 PM
Even better, switch to the Stompski coupler.
