Shift coupler bushing issues / 3rd set
This is now the third set of “genuine porsche” bushings I have ordered where the hole is oval. Is there a bad run of bushings or am I missing something? I order some aftermarket junk and they come in perfectly round and tight
Instagram: @TuitTech |
They're all oval. Parts Klassic sells the round hole ones, if they're in stock. Late 914s used the round hole. FVD probably has them.
https://www.instagram.com/johnwalker8704 8009 103rd pl ne Marysville Wa 98270 206 637 4071 Last edited by john walker's workshop; 04-25-2024 at 10:22 AM.. |
I’m pretty sure they are oval so that a certain amount of NVH doesn’t get through the linkage and into the cabin. I fitted a Stomski coupler a couple of years ago and get all sorts of noise coming through now. It’s really noticeable on road trips so I am going back to the original design.
https://www.pelicanparts.com/More_Info/RENTR18.htm?pn=REN-TR18&bc=c&q=brass%20shift |
Still here
That fit looks way worse than normal even for these oval bushings.
I can’t tell you how many of these couplers I have done over the years and this is the first I’m seeing this. I have never seen a oval or gap like this
Still here
I put these round hole, delrin bushings in my 85 last year. A little more compliant than brass. No slack, but no noticeable NVH either. Very happy with them. —Dave
https://www.rauchandspiegel.com/product/shift-coupler-bushing-delrin-round-hole/ Sent from my iPhone using Tapatalk
1985 Carrera 3.2 • Prussian Blue Metallic |
I learned something today.
NVH stands for Noise, Vibration, Harshness I had no clue what you guys were referring to above.
Mark '83 SC Targa - since 5/5/2001 '06 911 S Aerokit - from 5/2/2016 to 11/14/2018 '11 911 S w/PDK - from 7/2/2021 to ??? |
Me Too…………
Thanks for deciphering the NVH acronym. I had no idea what they stood for until you posted. Tony Last edited by boyt911sc; 04-25-2024 at 08:24 PM.. |
Curious if it is corrected by installing it in the coupler…
I tried there was no difference. I really have never noticed a gap/play like this in anyone I’ve done before. I would consider this excessive. I’m not expecting push tight fit, but this seems crazy
PCA Member since 1988
When you compress that bushing into the yoke, it will tighten up.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
As everyone has said, factory is sloppy, aftermarket tight.
Jim, I do not get what's the matter with the bushings? Why do you replace them? Shifting problems?
Thomas
1981 911 SC Coupé, platinum met. (former tin (zinc) metallic), Bilstein shocks, 915/61,930/16,WebCam20/21, Dansk 92.502SD,123ignition distributor with Permatune box as amplifier,Seine Systems Gate Shift Kit,Momo Prototipo. Want to get in touch with former owners of the car. Last registration in US was in 2013 in Lincolnshire/lL. |
Just for comparison.here is an original factory and it is owal.... Ivan ![]()
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
I took the aftermarket "round" one and oval'd it out just very slightly, figured Porsche had a reason. It shifts fine.
Phil
81 SC. 930/16 (us model) |
Getting ready to do the Shift Coupler, and Shift bushings. Does anyone know the pro/con of the following bushings for the Coupler:
Brass, Delrin, Powerflex, or OE/OEM?
Tim 1986 930 Gone:71,2,4 914's, 70T, 71T(RS),77S |
The 9 Store
Even better, switch to the Stompski coupler.
All used parts sold as is. |
