another squeaking wheel
It seems that most of the recent problems that I have had
are noise-related and not too serious (beside my worn valve guide), but extremely annoying. The latest in date: a high pitch squeaking coming from my left rear wheel. It is intermittent with the same frequency as the wheel's rotation, and that does not go away when I brake. As far as I can tell, the noise only appears on hot days after having driven for at least 20-25 minutes around town. Does this sound familiar to anyone??? Thanks Ludovic 1988 911 |
Sounds somewhat similar to my situation a few weeks ago, except it was my right front. I repacked the bearings, replaced the seal and it's all good now. Others will probably chime in with other possibilities, but I'd put wheel bearing at the top of the list.
...Bruce |
Left rear? I recently heard that. Just replaced the rear wheel bearing. Big job (kinda) but all is quiet now.
Troy
Troy Past: 1975 911S Silver Anniversary-rebuilt and sublime. Past: 1988 Carrera-backdated with a 3.6 and all the goodies. Present: 2011 GMC 2500HD with the 6.0 & 4x4!, 2004 Toyota Sequoia (wife's) |
Ouch! What about greasing the bearing to see if I goes away and does not come right back? Can I service the bearing without removing the whole wheel assembly?
Ludovic |
