What would cause a steering to pull to the right
Hi, my 77 911 ROW slightly pulls to the right. What are some possible causes? I know there is no play on the wheels in the front if I try to jiggle. Also, an alignment was done last year and it still went to the right after.
Thanks.
Old 06-23-2003, 01:26 PM
Friend of Warren
I suggest whomever did the alignment did not do it correctly. possible causes in no particular order: toe, camber, overinflation, underinflation, tie rods, ball joints, wrecked front end, worn out shocks, bent or worn out spindle.
Kurt V
Old 06-23-2003, 01:29 PM
Senior Member
Jdub's Avatar
A dragging caliper? Do both wheels turn smoothly without binding when the front of the car is up in the air?
Also, does this happen when you brake or all the time?
John
'78 Targa in Minerva Blue
The car has pulled to the side on braking a few times. Do you think when the alignment was done they would have noticed any of these possible worn out pieces. I won the alignment in a silent auction so at least it only cost me $50.
Thanks.
Old 06-23-2003, 01:34 PM
Oh, sorry. It always glides to the side. It is not a strong pull. It is just a slow, casual glide to the right. It is not as if I take my hands off the wheel and it would go off the road.
Thanks.
Old 06-23-2003, 01:36 PM
I had a similar problem (would drift to left more some times than others and especially while braking) and my front brake caliper needed a rebuild. Drives perfectly straight while braking/not braking. May be your problem if your alignment is ok
1980 911SC Targa 3.6L
Old 06-23-2003, 01:48 PM
I bought a caliper rebuild kit. Is this something I should attempt or will I just be opening a can of worms. Any special tools or tricks I should know about. 1 easy, 5 bad. How would you rate?
Thanks.
Old 06-23-2003, 01:51 PM
Calipers aren't too bad to do. You may want to have Wayne's book next to you. Getting the pistons out can be a bit of a pain since there are two, but it's doable. Also you will need something cut to a 20 degree angle. I used a small piece of sheet metal, but you could use cardboard or anything. This is to set the angle of the notch on the piston when you put it back in the caliper.
Old 06-23-2003, 02:28 PM
Friend of Warren
Thanks.
Argeo, slow down dude and think your way thru this. Before you go rebuilding calipers do what Jdub suggests and see the the wheel spins freely. Think your way thru the problem before trying to fix it.
Kurt V
Old 06-23-2003, 02:33 PM
North Coast Cab's Avatar
It could also be the steering rack. I'm fighting the same problem and come to find that the steering rack had very little lubrication and is worn. If you can put a little load on the wheels, but still turn them, you may hear the worming sound in one direction. Also, the grease could just be hardened and a clean and lube could fix the problem.
JG
1985.5 944 GTS
Old 06-23-2003, 05:00 PM
RETIRED
Joe Bob's Avatar
Mine pulled when the front pads got too low.....replaced the pads..no more problem.
2012 ML350 3.0 Turbo Diesel
Old 06-23-2003, 06:49 PM
Hi,
I'm not sure if you are experiencing the problem only on braking or not. However, Porsches like these are rather light in the front end. Depending of the tire size you have, and pressures, you may experience more or less wander like this with no real problem. Don't forget, most roads (if not all) have a crown to them. Some crowns seem to be more pronounced than others. They will draw your car to the right.
Also, some tires are more or less susceptible to tramlining. There was a good, succinct explanation of this in a recent copy of Grassroots Motorsports I think.
I'm just suggesting that if your car is aligned, you may not be having a real problem. Have you driven another 911 on the same roads recently?
Remember our friends: Warren, Ron, Grady, and Steve.
76 912E RS (i.e. "Real Slow"); 63 Volvo P1800 "S"; 71 Jaguar XJ6 Series 1; 05 GT3; 23 Cayman GTS 4.0; 97 Boxster
Old 06-23-2003, 08:01 PM
Thanks guys. No I have not tried to another 911 to see if the same problem occurs. Good suggestion. I had heard that car can have a tendancy to float.
Regarding the rebuild kit, I bought that last year. I am in no rush to fix. The car has plenty of other issues to keep me busy if I want.
I will try lifting the car and spinning the tire to check for catching.
Thanks again.
Old 06-24-2003, 05:40 AM
1fastredsc's Avatar
Send a message via AIM to 1fastredsc
Tire pressure can also cause this, how do i know, the tires mounted on my 44 on the left leak air at 6 psi a week. So i must check the tires once a week and refill the ones on the left. Usually by the end of the week, before i refill, it will mildly pull to the left.
2007 Mazda 3 hatch
1972 Porsche 914 roller with plenty of holes to fix
Old 06-24-2003, 06:24 AM
Corner balancing! U r in the same situation as I was. Don't go thru rebuilding until you check the corner balance.
How do I know? I experimented with 'messing up' the corner balance. Sure enough, car pulled left or right depending on which side/corner is loaded/lightened.
Old 06-24-2003, 06:50 AM
Agreed with cab83_750. Mine was drifting to the right, w/ or w/o brakes.
That's after I had my alignment done, and verified that my brakes were not dragging (by looking @ difference on brake dust on either side).
In any case, corner balance the car (shifted >100lbs) and the drift disappeared.
87 930 K27HFS/B&B/Twin-Plug... Megasquirted
Old 06-24-2003, 07:31 AM
I have some steering stiffness when first driving my 78 911 targa. How would one lubricate the steering box?
Tom Swafford
Old 06-26-2003, 08:52 PM
Tom,
I think you need to go to the smuggler's box and shoot some lubricant. You may want to search the PP archives as I think this was addressed before.
Good luck!
Old 06-27-2003, 07:21 AM
