Bad voltage regulator, do I need a complete alt for a 88 911
or can I just replace the voltage regulator. Seems to be over charging batteries. Obviously, the replacement of just the regulator would be cheaper.
90 C2 Cab Ruf Red/Blk 03 Caynne S L.Blue/Grey 03 996 TT Blk/Blk 04 996 Atlas Grey/Blk |
A recent book I just checked out (911 buyers guide), said that the alternators life is about 40,000 miles on most 84-89 cars. Might be time for a new one.
Like an engine an alternator has some parts that can last hundreds or thousands of miles, and some that have a limited life time.
A reputable rebuilder could probably rebuild your alternator for a lot cheaper than you could buy another alternator for. |
I replaced only the regulator and haven't had a problem sinse. It was a simple job, and seems to me to make sense to try that before spending $$ for an alternator as well. It is possible that there is a lot of life left in the alternator. Isn't overcharging usually a regulator problem?
Mike 1986 930 |
Somewhere in the Midwest
I have an OEM voltage regulator, new in box, never used!!!
I never got a chance to use it, and only to get what I paid for it! E-mail me if you are interested. |
I have a volatage regulator/Alternator repair and replace article for 84-89 Carrera's in the Tech Section of Pelican. Check it out.
---Wil Ferch
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
