Rtrorkt's Avatar
3.2 operating temp
What temps do those of you with 3.2 motors normally see during driving. Just had a new gauge put in but using the old sender. Previous gauge would read 180-200, 220 at the high end in the desert heat. The new gauge is showing about 240, fairly constant.
Any insights are welcome
'86 944T black/red, chip, fuchs 8's and 9's- Sold
'97 Boxster silver/red, big mistake - Sold
'99 C2, silver/black, RoW M030 - sold
"69 912 white w/ '86 3.2L (like the pic, just not the pic)
Old 06-04-2024, 12:47 PM
Double check with a hand held infrared, cheap and effective
Old 06-04-2024, 05:10 PM
rokemester's Avatar
There are some helpful threads on this forum around typical air cooled oil temps. My 87 hangs out around the 2nd hash mark, 90 degrees C. On a warm day in NEO 80 plus degrees ambient the oil temp gauge will indicate 194-210 F. It may climb a bit higher with prolonged idle, but will drop back once on the move.
Northeast Ohio
1987 Porsche 911 Targa
1966 VW Beetle, 6V
Old 06-04-2024, 05:11 PM
Driver, not Mechanic
On a day like today > 90 deg F ambient, in stop and go traffic, it goes all the way up to maybe 1mm below the third line, which, according to this thread, is 120 deg C.
Old 06-04-2024, 07:04 PM
917_Langheck's Avatar
Did you rate the new meter? Put the sender in boiling water and check the meter. Should be a half a tick above the 210° line.
If it not, adust the indicating needle until it does.
Old 06-04-2024, 10:10 PM
