Power Surge Event - Now No Spark
Hi all,
In an unfortunate circumstance I had a power surge event (12v to starter wasn’t bolted on and hit a heat exchanger). Now I’m chasing down some issues and have no spark.
The “event” popped fuses 7/8 (I think those are them) in the front trunk. Those fuses have since been replaced. I had the CDI tested and it is in working order. I tested the coil it is good. The starter works and seems to want to turn over, I’m just not getting spark. This rebuild also has 0 miles on it and had only 10 minutes of running time before this happened.
I’m trying to get ahead of this but I plan to test the ignition switch next.
Is there anything else I should be looking for/testing that could have failed? Any common failure points?
Old 06-05-2024, 08:35 AM
What year is your car and how did you test the cdi and coil?
We are dominated by the relatively small number of persons who understand the mental processes and social patterns of the masses. It is they who pull the wires which control the public mind.
Old 06-05-2024, 08:48 AM
1972 911T
I bench tested the coil using a multimeter. Unless there is a specific process of testing a Bosch coil that I was not aware of.
The CDI I had sent to a professional rebuilder who tested it and said it was all in working order. He had rebuilt it for me before i had the event.
Old 06-05-2024, 09:59 AM
Originally Posted by GeminiBlue911T View Post
1972 911T
Now, it's time to test it in the car, a 5 minute test. Most likely you have a three pin CDI which uses points to trigger a spark.
Just remove the coil wire at the distributor and place it about a 1/4 to 3/8 inches away from the base of the coil.
Then remove the black wire at the distributor input and momentarily ground it which should produce a spark.
Did your "professional rebuilder" help you troubleshoot this?
Dave
Old 06-05-2024, 10:58 AM
