3.2 AC question
I just added refrigerant to my car and is cooling down but I would like to know if there is a way to shut off the bottom vent by my legs so more air will hit my face from the tiny dash vents? Also, what is the best position for the three heater and fan levers when using AC. A bit confusing. Thank you. Nick.
Old 06-12-2024, 10:30 PM
famoroso's Avatar
You can either stuff some cloth into the bow tie vent (#9 in the diagram) to block it, or remove the vent and tape over the opening (you can reinstall the vent so you don't lose it and / or the screws).
Dashboard control levers are somewhat immaterial, I'd have all three of them fully to the left. Most importantly, have the heater levers between the seats all the way down/closed.
Frank Amoroso
911 M491 / M470 coupes:
1987 GP Wht / Blk "Apollo"
1987 Gemini Blue / Blk "Gemini"
1989 GP Wht / Blk "Vents"
Old 06-13-2024, 06:28 AM
Frank!! Thanks! I like the rag stuff idea. Easy, no one sees it!! I also closed the worthless tiny window vents.
Old 06-13-2024, 08:00 AM
My car is black on black so a bit tough.
Old 06-13-2024, 08:20 AM
That's fond- just deglaze
Hi Nick- Griffith's has also come up with a great solution. I believe you've got an '85, so I would let Charlie confirm, but those side vents may fit (even though the link says up to '83). Regardless, I've got his center vent, and it's a huge help.
https://griffiths.com/product/tri-kuehl-vents/
Missed Approach
Petra- 1986 Coupe
Old 06-13-2024, 08:25 AM
and from our Owner's Manual on your position question...
Missed Approach
Petra- 1986 Coupe
Old 06-13-2024, 08:33 AM
Thank you all very much.
Old 06-13-2024, 12:03 PM
85 As per handbook, I printed and laminated this. Not sure why it looks so big
Old 06-13-2024, 07:12 PM
Thanks, this is great!
Old 06-13-2024, 09:32 PM
