1986 911 Carrera Cab
1986 911 Carrera Cab rear seatbelt covers
Im looking to replace my 2 point back seatbelt covers and cant find a part number anywhere for the cover that goes on the reel/buckle side which is a bit wider
(#13 in red shown in diagram)
For the later Gs it's. 477 857 750 B. Should be the same for your application.
https://www.pelicanparts.com/More_Info/477857750B.htm?pn=477-857-750B-OEM
Frank Amoroso 911 M491 / M470 coupes: 1987 GP Wht / Blk "Apollo" 1987 Gemini Blue / Blk "Gemini" 1989 GP Wht / Blk "Vents" |
Thanks Famoroso
I did find that cover for the buckle insert side but the tongue.reel side cover is wider and not the same |
'82 SC TL
If it's the unique "curved, slightly rounded w/open end" cover in the picture.... good luck, it's available but not separate from the actual belt/recepticle, so big $$$, I've been trying to look for just the cover(s) to no avail. so started looking used...also no luck on finding near new condition ones, I wish someone would 3D print these
76'S 1st Porsche white/can/can early rebuild (boo) ![]() '84 Carrera cpe. all blk & stock 340k never a let down (might have been the best1) ![]() '87 Carrera cpe white/blue short flirt ![]() '89 Anniv. sil/linen very pretty miss her ![]() '88 928S4 5spd. blu/blu cmplt.SS exh.chipped lowered
Thanks for this info bud!
such a shame they only offer the 1 side cover replacement
Yep, only available separately on the reel side (which is what you asked for in #13, no?). On the buckle side, it looks like the seatbelt webbing was sewn into the bolt-in anchor AFTER the plastic sleeve was slid on. So, the only way to get the plastic sleeve on / off, short of unsewing & resewing the metal anchor, is to destroy the plastic sleeve itself by cutting it open longways, which defeats the purpose of replacement.
The sleeves are shaped differently reel side vs buckle side.
So if anyone ever tries to model this part in 3D, they would have to do it as two shells that clip together with tabs and notches ? Don't know if that's doable with 3D print.
Gilles RoW 88 Carrera coupé |
Something like that. The bolt-in anchor piece is wider than the top of the cover (where the cover meets the receptacle).
More than you ever wanted to know about G Body rear seatbelt receptacles
Rear inboard seatbelt cover deconstructed...
Now that I look at it, I'd wager the bolt-in anchor, connected to the inner receptacle via stitched seatbelt webbing is passed through the plastic cover and then the inner metal receptacle structure is riveted on and, finally, the outer plastic receptacle structure and the red release button are snapped on / snapped together. I say this because the top opening (narrow end) of the plastic cover is 33mm wide and the bolt-on anchor is 46mm wide... ![]()
