Anyone in Chicago with 16x7s on the front that I could use to check for fitment on?
I'd like to put 7s and 8s on my car, but it's lowered quite a bit. It's also corner-balanced, feels great, and I've never had to touch it in almost a decade, and I'd rather not mess with ride height if I don't have to.
I've done the math, and it's tight, so it could go either way rubbing the front fender lip or not. Best way to get the definitive answer is to see if I could find someone local with a set they'd let me throw on for five or ten minutes, is mount them, check for static contact through the range of steering lock, and then drive around the neighborhood to check for clearance at lock and under braking. It's worth asking! |
other helpful things to do: shave the fenders lips and use a bit more neg camber . |
Unfortunately, I'm not anywhere near Chicago. But I run 16x7s with Michelin Sport AS3+ 205/55-16 at all 4 corners on my 1973. I don't have interference. Your SC should have no less clearance than my car.
The brand of tire also makes a difference, as some "205" are a little rounder or more square at the shoulder than others. Running a 205/50 would also drop the front end slightly (1/4"?) with no change in geometry. This is what I would do if I was changing my wheels and tires and did not care whether I could rotate the tires from front to rear. |
You must have missed this Quote:
do a search if you don't want to believe me |
I’ll go take ride height measurements when I’m home again. Was meaning to do that and look up my alignment settings etc and contribute to the setup thread.
I'm in Des Plaines and coincidentally I have an 87 with 16's on it in my garage. It's not my car. This particular car rides very low and there is lot of evidence of inner wheel well rubbing. One of the things that's being done to the car is raising the ride height. I might be able to accommodate you.
Mark, thanks for that. I’ll PM you tomorrow to see if we can arrange something.
Older Fuchs 7x16 weigh ~14#+/- newer versions seem to be somewhat lighter Here's a comparison of 2 different 7&8x16 Fuchs setups on an SC/Carrera, I arbitrarily choose A052 because the are available in all the sizes chosen here. I much prefer setup #1 on the left as it moves ~26lb-ft from spinning up the wheels to accelerating the car and the lower profiles of the tires will generate more mechanical grip. http://forums.pelicanparts.com/uploa...1718290783.jpg scrub radius does change when going from Fuchs 6 to 7 w/ 7s it is a large 52.4mm w/ 6 it is 65.1mm both of these are large by modern standards, most cars now run 0 to -6mm for s/r |
Bill,
Yes, I know most cars have much lower scrub radius than they did decades ago. I'm assuming it was substantially lower on the original 911 with its skinny little tires, too, if still positive. I'm surprised scrub radius is slightly lower on the 7s than the 6s - I would have supposed the opposite. So that change would suit me. I would imagine that changes in SR from more camber or from a smaller diameter are trivial. If I do put them on my car it's going to be a package ready to just bolt on with the stock 16" sizes. I appreciate all your suspension and tire input over the years. |
Otter,
PM sent |
Otter: The reason the SR is less on the 7's than the 6's is a combination of different offset and wheel width. The edge of the 6's sits as close to the fender as the edge of the 7's. Since the 7's are wider, they are wider to the inside of the wheel well. Thus the centerline of the 7's is closer to the centerline of the car by 1/2", and the SR is 1/2" less.
Per Bill V, the SR of the 6's is 12.7mm more than the SR of the 7's. 12.7mm is 1/2". BTW, because the 7's are wider to the inside, it's common for 16x7 tires to rub the inside of the wheel wheel, rather than the fender. |
My RS clone (1970) runs 944 Turbo 7s up front with 9s in the rear. I also rolled the front lips, Louisville slugger style.
I said I did the math a while ago, and I did, but it was so long ago that I apparently conflated my takeaway with that on my Fiat. I got some Biturbo wheels to put on it that are an inch wider and that increase is split between in and out. I didn’t really realize until Bill’s comment that all the extra went inside on the 7s. Another commenter who is local shared photos with me of wheel rub witness marks on the inner fender of his car. I’ve found a local set that I can swap onto the car to test and I’m going to see how they fit on Sunday.
PeteKz and Otter74 -- interesting! Still trying to figure out why the outer (not inner) edge of my right front tire shredded on (and pulled out) my right front fender lip when I switched from 16x6 fronts to 16x7 fronts (without otherwise changing alignment/etc.). Rolling my front fender lips resolved this for me.
here's a detailed comparison of a Fuch 6 and a Fuch 7, the 944 7 is the same except that it has increased caliper clearance, both have the same 205/50 x16 tire mounted
http://forums.pelicanparts.com/uploa...1718474827.jpg both 6 & 7 have the same backspace the extra inch is all on the front space. the scrub radius is solely dependent on the wheel o/s aka ET the 6 has ET38 the 7ET23.3, the difference in ET is 12.7 w' the 7's centerline closer to the hub face. |
Otter, I’m in Chicago and run 7s up front on Yoko A052s (I think). I ended up having to roll the inner fenders as I bottomed out a couple of times. Probably a hair too tight.
You’re more than welcome to come check them and think we’ve exchange deets in the past. |
So now I’m curious how, given that the extra inch is all on the back side, some people have gotten rubbing on the fender lips with 7s but not 6s.
I’ll find out tomorrow what happens on my car. |
I’d like to thank those that offered help. I went by @HLcass’s house today, swapped on the front wheels from his car and went for a drive. No clearance issues at all. I appreciate it!
but the extra inch is all on the front side |
I have 8ET25 on mine and have used 225 and 235 tires, The car is very low. top of the fenders is the same height as my 993 which is at 993RSR height(704mm to the top of the fender) no rub on the inside. |
all have the same lip width doesn't matter if they are 15 or 16, 911 or 944 part #s the only difference w/ the 944 versions is increased brake caliper clearance and countersunk lugs on the 944 versions Replicas may or may not have the same 23.3mm ET and probably don't have the narrow lip spec that all Fuchs have. All Fuchs have ~.35" lips almost all modern wheel have .5" The most different versions of Fuchs can be seen in the 6's and a very rare 7r early 6 have 42mm deep valley at the petal ends and late have 20mm deep valleys early are tube type w/o the safety humps seen on tubeless http://forums.pelicanparts.com/uploa...1718571421.jpg This is a 7R ET49 no tubeless safety hump http://forums.pelicanparts.com/uploa...1718571518.jpg deep 6 on left '72 on 6 w/ tybeless safty hump http://forums.pelicanparts.com/uploa...1718571548.jpg 6 w/o hump http://forums.pelicanparts.com/uploa...1718571605.jpg 7 944 part # w/ recessed lugs and larger caliper clearance on right 911 7 on left http://forums.pelicanparts.com/uploa...1718571718.jpg http://forums.pelicanparts.com/uploa...1718571718.jpg |
Thanks for the correction on the 944 7s, Bill. I’m not sure why the tires on that car are rubbing (I haven’t seen it, but the wheels looked like 6s in the photo)
My ideal wheels would be a set of 7/8x16 Group 4 Campagnolo replicas, but none of those available not within my budget :) |
Bill V is usually right about this stuff (and schools me), but I could swear that the 16x6's sit almost as close to the fender as the 16x7's. I wish I had a 16x6 laying around so I could compare them side by side. I do have a pair of 15x6 and a pair of 15x7, so I could check the ETs and compare those...
Here are the specs for most Fuchs used on 911 http://forums.pelicanparts.com/uploa...1718725115.jpg and the fitment envelopes http://forums.pelicanparts.com/uploa...1718725115.gif |
I'm following this thread because I want 8 x 16 for the rear of my SC. May move the 7's to the front. Bill, it seems I can buy 911 or 944 8" for the rear, either will work, correct? Thanks
They are ET23.3 and almost fit the front, some have used them there but the cost is higher ride height and more aggressive camber setting for the back of an SC/Carrera you will want 8s to have ET10.6 ore a little higher like ET 8 or so. The lower the numerical ET the more the tire sticks out and the less lip room. you will want 7ET23.3 front and 8ET 10.6 rear tires could be 205/55 or 205/50 front and 225/50 rear or for better performance 205/550 and 225/45 |
Thanks Bill. I got the 7" discussion mixed into my 8" question....sleep will help me.
Lowered with 7&8 16s
My car came lowered from the PO with 6&7 16s, 20mm spacers and 205/55 225/50 tires.
I checked the fenders were already rolled a bit so I switched to 7&8 16s, kept the tires and ditched the spacers. No rubbing or contact issues with the new setup. http://forums.pelicanparts.com/uploa...1718897166.jpg |
Thought I'd update this thread - bought a set of 7s and 8s, they're on the car, all is great.
Found last weekend that I do get some rubbing on the left rear under hard cornering with bumps:
http://forums.pelicanparts.com/uploa...1729194648.jpg Doesn’t bother me - including this for future reference. |
In the back of an SC/Carrera 225/50 x16 on 8 ET10.6 will have plenty of room at any ride height |
Check your camber. That will affect clearance too.
Will look up alignment settings. Car was aligned and corner balanced a while back, and no reason to expect the rear to have changed. With the characteristic asymmetry these cars often has, my left rear is about 1/2” closer to the fender than the right rear. Will check when I put car on stands and remove wheels to do maintenance, but IIRC these are ET10.6. Rubbing is roughly where that smudge happens to be, on the back side.
How did you determine the 1/2"? |
| All times are GMT -8. The time now is 03:05 PM. |
