-   -   No Spark (http://forums.pelicanparts.com/porsche-911-technical-forum/1163309-no-spark.html)
mysocal911 07-04-2024 07:22 AM
Originally Posted by ant7 (Post 12277474)
Hi Wazzz,
All three had their solder removed, and re-soldered as in the "New Solder" pick.
However, although that pin looks to be bad in the pick, its just a trick of the light, because with the naked eye, it looked fine!
It's always best to bend the pins over before re-soldering, as shown in post #19.
wazzz 07-04-2024 07:35 AM
Hi Wazzz,
I know you did reflow them. I was just pointing this one as a possible culprit.
By the way, I can see part of a tube amp diagram on your desk, so you must know what you're doing. ;) :D
mysocal911 07-04-2024 08:02 AM
http://forums.pelicanparts.com/uploa...1720105192.jpg
Have you called them?
ant7 07-04-2024 08:22 AM
Hi Wazzz,
No worries, :) Very observant of you, I am indeed an audio technician, I deal mainly with Valve/Tube equipment, mostly for Musicians these days!
ant7 07-04-2024 08:28 AM
Hi Dave,
In answer to your question, Why would I ?
I think Steve did actually comment earlier on, so he's obviously been following the thread, if he had any reservations of this issue being related to the chip, surely he would have said so ? :confused:
Originally Posted by mysocal911 (Post 12277497)
mysocal911 07-04-2024 09:06 AM
Originally Posted by ant7 (Post 12277513)
Hi Dave,
Help, e.g. repair suggestions or ideas about the failure?
wazzz 07-04-2024 09:43 AM
Originally Posted by ant7 (Post 12277509)
Hi Wazzz,
Interesting, I should show you my take of a small guitar tube amp I built a few years back from a schematic I found on the web. Only 2 or 3 watts but a killer amp. :D
ant7 07-04-2024 10:21 AM
Indeed, Although I have to warn you I may have a few of my own! :D
ant7 07-04-2024 10:23 AM
If anyone including yourself had indicated that it may be something to do with it, of course I would, so in your opinion; do you think its related ? I should indicate that the chip has been on the car for around 10 years now, so not a recent adition.
pmax 07-04-2024 11:19 AM
http://forums.pelicanparts.com/uploa...1720116980.jpg
Pic's blurry so hard to tell but what's the discoloration ?
dkirk 07-04-2024 07:57 PM
Several years ago I had a no-start situation with my '88. Fortunately it occurred in my garage. The DME failed open circuit at the conductor path shown in the photo. Sent to Steve Wong for repair...quick turn-around and very fair price.
http://forums.pelicanparts.com/uploa...1720148125.jpg
ant7 07-05-2024 01:05 AM
Cheers Dave,
Hopefully Steve will contribute further to this thread when he has anything to add.
Ant.
ant7 07-06-2024 10:36 AM
Hi All,.
Spent some time over the last day or two going through a few things like checking and re-gapping the flywheel senders, etc.
Quick update, left the car until early this afternoon before trying to start it, turned the key and it fired straight up from cold, great I thought, although I noticed that it seemed flat when you tried taking it above idle, but eventually it did seem to respond normally, well with the car standing still anyway, took it out for a spin and it was obvious as soon as I wend out the gate that something wasn't right, put your foot down, and it would hesitate, then it would cut in and pull ok for a split second then back to flat and bucking as soon as you tried to give it any beans, so, not sure what the heck is going on with it now, I guess some more checks are in order, However; for now I do seem to have gotten somewhere as it seems to start ok every time.
Anyway, in the meantime; if you have any thoughts...
ant7 07-10-2024 08:37 AM
Had another look at the car over the last few days, and long story short, the vacuum pipe going to the fuel pressure regulator was sucking air, which was obviously affecting the fuel pressure, took the car out today, and all is well again, so just a heads up, check your vacuum pipes first if you get a similar issue. :)
Ant.
ant7 07-30-2024 03:18 AM
Well, back to no start again,:rolleyes: long story short; changed the ECU for one that was kindly lent to me, and the car fired straight up, and ran fine, so,,, any of you ECU wizards out there who can point me in the right direction for why this might be happening to my original ECU, your thoughts would be most welcome. :)
Schulisco 07-30-2024 03:45 AM
https://www.google.com/search?q=motronic+porsche+ecu+repair+service+uk
ischmitz 08-17-2024 05:47 PM
FW decoder could be damaged. Your DME needs to be repaired.
ant7 08-19-2024 09:41 AM
After spending a bit time searching out ECU repairs in the UK, and speaking with a few, I decided it may be best to send it off to be checked, however; before packing it, I decided to plug it back into the car just for the hell of it, and.... the car fired right up, and ran fine! :rolleyes:
I am now beginning to suspect there may be something odd going on in the large ECU plug itself, so for now, I am going to hold off sending the ECU off until I have time to look at the plug and do some further testing etc.
Ant.
Schulisco 08-19-2024 12:05 PM
Broken soldering joints...not uncommon on 40years old units...but when you diy you should definitely know what you do. Otherwise take it to an experienced electronics guy...in the end after the season I would let it overhaul either. The condensators will also fail over the decades...
ischmitz 08-19-2024 01:17 PM
Classic symptoms of deteriorating solder joints. It works fine for days and then out of the blue shuts down leaving you stranded.
The high currents in the ignition final drive causes electro migration in the micro cracks and that weakens them over time. The spark becomes weak and eventually leads to complete failure. Sometimes you can hit the box hard and it’ll come back before failing again.
