No Spark
Hi All,
Its been a while, anyway, as the title states, no spark on my 1985 3.2, changed the Flywheel sensors, changed the DME Relay, made sure the both relays inside the DME Relay are activating when their supposed to ie; ignition on, one relay pulls in, turn the key to start, the second relay also pulls in operating the fuel pump etc. While checking for spark, as the ignition is switched on, I get one spark from the coil lead, and that's it, no spark when cranking etc. Help!!!|
"But instinct is something which transcends Knowledge We have undoubtedly certain finer fibres that enable us to perceive truths when logical deduction or any other wilful effort of the brain is futile" Nikola Tesla |
I suppose a defective ECU due to either cold soldering points and/or bad capacitors. Also a defective ignition coil may cause these symptoms.
To rule out a defective DME relay use a cable bridge instead: https://dorkiphus.net/porsche/showpost.php?p=193387&postcount=3
1981 911 SC Coupé, platinum met. (former tin (zinc) metallic), Bilstein shocks, 915/61,930/16,WebCam20/21, Dansk 92.502SD,123ignition distributor with Permatune box as amplifier,Seine Systems Gate Shift Kit,Momo Prototipo. Want to get in touch with former owners of the car. Last registration in US was in 2013 in Lincolnshire/lL. |
Dave |
Tried that Dave,
The problem was there before changing them, that's why I figured that was the first place to start after the DME Relay. I suspect its an ECU issue, but just want to make sure I haven't missed anything else before condemning it, I have opened up the Motronics unit to check for anything obvious, nothing burnt, all diodes check out, guess I will need to look further into it, Anyway, all input welcome.
You may remember the guy that posted that, since you've been a long time Forum poster.
Dave |
Hi Dave,
Yes, I remember reading that, I have voltage at the coil, and I do get one initial spark from the coil lead to ground when the ignition is first switched on, once the engine turns, no more spark, which is odd, I am going to test for voltage at the Injectors next. Quote:
You need to check the AC voltage of the sensors. Hopefully, the reference sensor pin isn't missing/damaged.
Dave |
Agree!
![]() However; as stated in my first post, they are brand new fitted yesterday, but as you say; still need to check that they are putting out a voltage.
"But instinct is something which transcends Knowledge We have undoubtedly certain finer fibres that enable us to perceive truths when logical deduction or any other wilful effort of the brain is futile" Nikola Tesla Last edited by ant7; 06-22-2024 at 10:37 AM.. |
Well, after removing the ECU [Motronics unit] and opening it up to check for bad connections, or any signs of burning, I found nothing, inside was very clean, removed bottom plate, and inspected the soldering on that side too, all looked fine.
Replaced the unit back in the car, turned the key, and the car fired right up, and ran fine, I switched it off after about 10 mins, turned the key again, and it re-started again with no issues.Next day, turned the key, no start again, so at this point I am at a loss, any input very welcome as its now driving me a bit mad!Ant.
Dave |
I get that Dave,
And will have to remove it once again, and do some actual checks on component values, and look for broken wiring between the two board layers etc. A...
If you manage to make it start again, keep it running and try to wiggle things like the ECU, the ECU connector, the DME relay and its connector and associated loom. See if it dies when doing so. That may point you to something.
The no start situation may also be due to a bad ref sensor or related circuit and logic, as Dave already mentioned. Once the car is running a bad ref sensor signal, whether due to the sensor itself or its logic circuitry, may not be noticed. The speed sensor is able do deal without it, provided it is good. But for the car to start the ref sensor signal needs to be good at least for the duration of cranking, until the engine runs. But you probably know all this.
Gilles RoW 88 Carrera coupé |
Hi Wazzz
Yes, good call, I am going to try it again today, the Reference sensors are brand new fitted last week, it has started and ran fine since fitting those, I changed those initially when the car first refused to start. Quote:
If it's both, then focus on the sensors. Since there're new, that's unlikely the problem. Again, read the link in post #5. Have you checked for an injector signal, not just voltage? If the injectors are pulsing, then it's the spark output of the DME ECM.
Dave Last edited by mysocal911; 07-01-2024 at 10:14 AM.. |
Email the company referenced in post #5. They'll tell you what has the highest probability of the cause of your problem.
I've used them numerous times for help.
Dave |
ant7, most likely the ECU is failing and needs repair. mysocal911 knows that and why he is pretending to be a different person directing you to post #5, who is himself under a different alias who was banned, to get your business, by asking you PM him instead of discussing solving your problem out in an open forum. Is that even allowed?
BTW, someone said (several times) that our host has a repair service for many things, especially the Motronic ECU. Just type 'Motronic repair' in the search box at the top of the forum page. Good luck. |
they always enjoy helping Porsche owners. They said the highest probability of failure on the 911 3.2 DME ECM is the ignition driver circuitry being intermittent. This agrees with your post 9; Quote:
This mainly occurs on the later ECMs, where the circuit board was changed to fiberglass. Hopefully, re-soldering these pins will solve your problem.
Dave Last edited by mysocal911; 07-02-2024 at 05:47 AM.. |
Another view of the ignition driver area;
Dave |
Hi All,
Well, took out the ECU again Yesterday, looked at the main solder joints that I know from what a few of you have stated are the first port of call, when you get the no spark issue. Although they looked to be fine, I decided to re-do many of the joints, including the large transistor, and what I deem as its drivers too, I removed the old solder first, and re-soldered using original lead and tin solder I use for repairs and re-work on older Audio Equipment, as it is much more forgiving as far as flex and vibration than modern Non-leaded etc. Anyway after completing the task, I decided to leave all the covers off [just encase] and plug the unit back in the car naked, and see if it would now start, sure enough, it started right up, and ran fine as it always has, so let it run for a while, switched off, re-started it a few times, no issues. I then removed the ECU and re-fitted all the case work, and tried it again, sure enough it started fine again. I am going to wait until tomorrow now and see if it will start from cold before I re-fit it permanently to the floor, but for now I am quietly confident, lets see, I will update you all soon. Thanks to everyone who contributed so far. Ant.
"But instinct is something which transcends Knowledge We have undoubtedly certain finer fibres that enable us to perceive truths when logical deduction or any other wilful effort of the brain is futile" Nikola Tesla Last edited by ant7; 07-02-2024 at 07:18 AM.. |
