-   -   Airbox strap too short (http://forums.pelicanparts.com/porsche-911-technical-forum/1163407-airbox-strap-too-short.html)
6cylboxer 06-23-2024 07:33 PM
I had a backfire on my 1977 911S that fortunately the pop off valve did its job, but it broke the airbox straps. I ordered through our host the Porsche 930-110-365-00 and tried to install them. As seen in the pictures, it was short, no matter how much i pulled to stretch the strap, i could not reach the tie point.
http://forums.pelicanparts.com/uploa...1719196234.jpg
Measuring the new strap alongside the old, the length difference is significant as can be appreciated on the photo.
At the end i found a temporary solution while I figure out if I need a different strap
pmax 06-23-2024 08:10 PM
Someone else reported the same.
http://forums.pelicanparts.com/porsche-911-technical-forum/1160767-broken-cis-air-filter-strap-lower-mount-fixed.html#post12239715
proporsche 06-24-2024 07:40 AM
there use to be 2 different types-lengthwise..early 911s up to 77 had the longer strap after on 911SC it was shorter...but nowaday who know who makes them ,it is possible they made a copy from the earlier type..?
Ivan
EC900 06-24-2024 12:42 PM
I ordered one from Pelican a while back for a 2.7 airbox, I can’t find the receipt at the moment but it was the part number with the 911- prefix as seen on the PET, and measures about 13-1/2” .
http://forums.pelicanparts.com/uploa...1719258119.jpg
6cylboxer 06-24-2024 02:41 PM
Thank you Pmax, proporsche and EC900 for the information - I was not aware that there existed two different straps with different lengths. Next time I will be more careful before i click the Buy button on Pelicanparts
