Tightness of retaining nut on valve adjusting screw?
I'm working through my first valve adjustment and find that the retaining nuts on the adjusting screws are super tight. I can't loosen them with just a regular 13mm combination wrench. I have to use a pretty long handled 3/8 driver. That seems way too tight to me. Does anyone have a torque setting for the nuts or any other suggestions? The previous work was done by a very well respected shop and all of the nuts are in good shape. Thanks for your help.
Old 06-30-2024, 04:52 PM
I believe it’s around 18ft lbs but I doubt anyone uses a torque wrench, just tighten them up good with a small box end wrench.
We are dominated by the relatively small number of persons who understand the mental processes and social patterns of the masses. It is they who pull the wires which control the public mind.
Old 06-30-2024, 06:38 PM
It's a 914 ...
stownsen914's Avatar
It's common for people to overtighten them unfortunately. And distort the threads on the elephants foot adjuster.
Old 06-30-2024, 08:32 PM
206 637 4071
Old 07-01-2024, 05:13 AM
Jeff Alton's Avatar
Yep, see this all the time! Rounded off nuts, tight threads from too much stretch/distortion.
Cheers
www.turn3autosport.com
Old 07-05-2024, 11:45 PM
Targa_PB_78_SC
mike sampsel's Avatar
Originally Posted by 5495bb View Post
I'm working through my first valve adjustment and find that the retaining nuts on the adjusting. Does anyone have a torque setting for the nuts or any other suggestions? The previous work was done by a very well respected shop and all of the nuts are in good shape. Thanks for your help.
I just use a small 13 mm wrench (6- 8 inches long), as such (I'm not a gorilla) I can get them snug enough and not too tight. You can use a stubby wrench and never get it too tight.
BareRearedRookie
Old 07-06-2024, 05:11 AM
Fixer's Avatar
Any red locktite on them?
My wife overtightens everything lol
Old 07-06-2024, 05:44 AM
Thanks you guys. The job is finished now but I had to use a 10 1/2" long 3/8 driver to get all the lock nuts loose. I tightened them pretty well with a 6" long box end. Save for the usual gap drift when tightening the nuts I didn't have any difficulties. What are the indications that the threads on the elephant foot have been damaged?
Old 07-08-2024, 03:12 PM
It'll distort the threads. If you run the adjuster screw all the way up, the nut should smoothly turn all the way down. If it stops, the threads have been damaged.
Old 07-08-2024, 09:06 PM
Yeah man, and this sucks. I redid my cams and rockers a couple years back and so many of the adjuster threads were absolutely junk. I was able to get most of them off but I think the rebuilder had to cut one off of the rocker.
1982 911SC
Old 07-09-2024, 05:42 AM
Location: Just a little north of 13669/Nation's capital
Send a message via AIM to brighton911
No need for Loctite, correct torque on the lock nut and you are good to go. Also, unless all the oil was cleaned off both threads, it wouldn't do anything.
1986 Targa Guards Red
2021 MT09 SP
Old 07-09-2024, 11:20 AM
Darn, I didn't do this test but I will next time I'm in there. Thanks again.
[QUOTE] It'll distort the threads. If you run the adjuster screw all the way up, the nut should smoothly turn all the way down. If it stops, the threads have been damaged
Old 07-09-2024, 11:46 AM
PCA Member since 1988
Has anyone seen the adjuster locknuts come loose? From what I can gather, it's pretty rare.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 07-09-2024, 04:46 PM
