Head Temp Sensor
could someone post a picture of where this sensor is located?
'86 944T black/red, chip, fuchs 8's and 9's- Sold '97 Boxster silver/red, big mistake - Sold '99 C2, silver/black, RoW M030 - sold "69 912 white w/ '86 3.2L (like the pic, just not the pic) |
Brilliant, thank you. EC
Also a pretty picture:
![]() https://rennlist.com/forums/911-turbo-930-forum/276047-tech-help-installing-cyl-head-temp-sensor-special-tool-needed.html Also here's picture about the sensors with their location and values to test: ![]() taken from Heidi & Franny's YT video series about "Shamoo", their white 3.2 Carrera project: https://www.youtube.com/watch?v=-2rvMKMqQ2k&list=PLESd2KXwHSVKKl3FxYSFB3rGKZTsfWpQp Thomas
1981 911 SC Coupé, platinum met. (former tin (zinc) metallic), Bilstein shocks, 915/61,930/16,WebCam20/21, Dansk 92.502SD,123ignition distributor with Permatune box as amplifier,Seine Systems Gate Shift Kit,Momo Prototipo. Want to get in touch with former owners of the car. Last registration in US was in 2013 in Lincolnshire/lL. |
![]() Uhhm. That's, like, not correct. This has been covered here several time before - including links to Bosch's datasheet (which really isn't very hard to find): Bosch NTC datasheet (PDF) The nominal resistance of a Bosch NTC sensor is 2.5kOhm @ 20C +/- 5%. At 0C, Bosch spec it as 5896 Ohms. Therefore, the acceptable range - to be within the stipulated tolerance - for that sensor at 0C would be 5615 - 6190 Ohms. And both 4.4KOhm or 6.8KOhms @ 0C are out of spec. It's not as important what the sensor reads at 90C; I've tapered my warmup cycle trim to nothing at 60C because the motor is warm enough it no longer needs any. However, Bosch spec 89 Ohms, so the tolerance range +/- 5% is 84.75 - 93.45 Ohms.
'77 S with '78 930 power and a few other things. |
The head temperature sensor is a bit awkward to get to. Besides the location, a special socket is needed due to the attached wire. I cut a slot in a cheap deep socket to get it out. This turned into 2 sockets due to the matter that the new 2 wire sensor uses a different size than the old single wire sensor.
Ed 1973.5 T |
And don't cross-thread it going in and don't over tighten because it can snap off.
Also, the Bosch NTC you refer to does not match the sensor used for CHT. The one used for CHT has a non detachable lead with connector at opposite end, while the one you point to has connector with no lead. Thread size and wrench size are also different.
Gilles RoW 88 Carrera coupé |
Bosch developed their own compound for their NTC sensors. They use the same compound across the entire range of NTC sensors they supply - and packaging variations such as grounding/# of leads, thread size, sensor reach etc etc make zero difference. Because the chemical composition of the thing inside that does the work - all the same. Which is borne out by Bosch's own datasheet, the sensor calibration tables provided by multiple aftermarket ECU suppliers, and 10 minutes worth of high-school level observation with rudimentary tools like a DMM, IR thermometer and a stove/heat gun. Other manufacturers such as Magneti Marrelli (as used by Ducati & Fiat at least, and I think some years of Land Rover), developed their own NTC compound. And their sensors have a different temperature curve and a different calibration table. Quote:
MoTeC provide a calibration table as a preset for the industry-standard "Bosch 2.5K NTC sensor" that exactly matches the curve represented in the Bosch datasheet. I didn't even have to type it in.
Well I'm not saying you are wrong. You seem to know a lot about those NTC sensors and their curves.
But the figures that you said are not correct in the pic posted by Thomas above (and that come from the H&F YT video) are the exact figures found in the Porsche Workshop Manual. I double checked them before posting.
1. 2.5K < cold < 3.5K ohms 2. engine at normal op temp - < 200 ohms
Dave |
I am confused. Porsche says that from 60 - 85° F (15-30C) the resistance should be 4.4 - 6.8 k.
But the linked Bosch datasheet says Nominal resistance: 2.5 k ± 5 % at 68F (at 20°C)...but does not seem to be the same sensor. If I have surging idle and mine reads 2K with a cold engine (ambient temp at 25C) The linked Bosch data says it should be 2,500 - 1,707 at 20 -30 C...so do I call it good...or do I use the Porsche info and replace it? Does anyone have a new one they can put on an ohm meter and see what it reads cold?
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo http://www.pelicanparts.com/gallery/fintstone/ "The problem with socialism is that you eventually run out of other people's money" Some are born free. Some have freedom thrust upon them. Others simply surrender |
Mine is good and reads 2.5 kohms at 22°C with engine stone cold, so I'm tempted to think yours is good too, as it reads 2K at 25C.
As Dave mentioned above, accuracy is not crucial for this application, so long as values are in range. Here is a few values I once copied from this board: 0 degrees C – 4,400 to 6,800 ohms 15-20 degrees C – 1,400 to 3,600 ohms 40 degrees C – 1,000 to 1,300 ohms 80 degrees C – 250 to 390 ohms 100 degrees C – 160 to 210 ohms 130 degrees C – 90 ohms
Thank you!
