1978 911 Carrera Coupe???
Hello,
I just received my Porsche Production Specifications Certificate. Under Model Year/Type is has “1978 911 Carrera Coupe”. It is a ROW car originally purchased in Germany. This should read 911SC should it not? Is this simply an error or is there such think as a 1978 911 Carrera Coupe? Thanks
1978 RUF 911SCR |
there were Carrera models from '73 to '77 and then again all 911s were Carrera from '84 to '89 '78 to '83 all 911 were SC
I had the opposite of sorts.
I called Porsche Classic (1.800.PORSCHE) to inquire about a replacement for a damaged PPS. When they looked up my VIN to confirm, they read out the info…1977 911 SC was on their records, not S Coupe which was correct on the PPS. Obviously a mistake which they corrected. Probably a drop-down list entry error. But for getting a new PPS, one or a hundred….just pay the appropriate fee for each. |
I'm not that guy - but some guy may chime in and say that SC stood for "Super Carrera" . . . . Fact remains that for the Classic Certificate it truly does seem to be a drop-down error as stated above as I know for a fact that "911 SC Coupe" is an available option. -
1973 Porsche 911 RS 1981 Porsche 931 Euro-Intercooled-GT 1984 Porsche 911 Euro Carrera widebody 1987 Porsche 924s Rallye Spec Instagram: @soyracer Last edited by SoyRacer; 07-16-2024 at 10:50 AM.. Reason: typo |
As a data point: my '78 SC (built in Sept '77) says "1978 911 SC Coupe" on the CoA.
1978 911 SC (3.2SS, EFI, 993SS cams + the trimmings) Dynamic Comp Ratio calc: https://dcr.questionable.services/ • Gearset & Ratio calc: https://ratio.questionable.services/ |
A car built in September of 1977 is a 1978 model year car.
Mike 1976 Euro 911 3.2 w/10.3 compression & SSIs 22/29 torsions, 22/22 adjustable sways, Carrera brakes |
I received word back from Porsche that it was an error and they will be sending me a replacement. Doesn’t build a lot of confidence that the rest of the information is correct.
1978 RUF 911SCR |
Not sure anyone is disputing that “911 SC Coupe” is an option. Why wouldn’t it be? The point a previous poster is making is that there is no such 1977 911 SC.
Ass-engine Nazi slot car -- PJ O'Rourke |
Still here
Of course it does. What else can the S mean ? Must be a relief you didn't get the regular Carrera ! |
Posting a VIN would clear it all up
