cis mixture
I just want to make sure I understand this.
The screw between the fuel distributor and intake boot controls the "idle mixture". when the engine comes off idle that adjustment means nothing and the only thing that controls the mixture is control pressure. do I have this right?
big AL '77 911 |
No, you are changing the air plate versus fuel control valve height relationship. However the effect may not be proportional.
Re: cis mixture
Thank you for your time, |
Senior Member
Porsche CIS has no special magic compared to other CIS. Fuel pressures have an effect on how hard it is for the moving air to displace (raise) the sensor plate, but the adjusting screw simply changes the position of the plunger in the fuel distributor, at a given sensor plate position.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
The sensor plate lift is controlled by the control pressure regulator.
When the engine is first started, the pressure in the system at the fuel distriutor is low allowing the sensor plate to lift higher allowing for a richer fuel mixture. As the engine warms up, the pressure on the fuel distributor increases thus leaning out the fuel mixture The control pressure regulator alows more fuel to flow through it when it is cold and less fuel to flow when it's warmed up. More fuel flowing through it reduces the pressure on the fuel distributor enriching the fuel mixture, less fuel flowing through it increases the pressure on the fuel distributor leaning out the mixture. You are correct in stating that the adjusting screw only affects the idle. Hope this info helps. Steve "A Porsche does more then just go fast in a straight line"
SteveKJR Proud Owner of a 78 911 SC Targa "A Porsche does more then just go fast in a straight line" |
The screw will adjust the mixture across al air flow amounts, but its effect is most dramatic at idle.
