Stahlwerks.com
jhelgesen's Avatar
Send a message via Yahoo to jhelgesen
Stuck nuts r' us
Why is it everytime I go to take something off my car or engine, it's been put on by a 1000 lb gorrilla?
First I try to take my belt pully off my 3.0 crank tonight (dummy me didn't take it off when the crank was still in the block and I could have locked the flywheel). Impact wrench wouldn't do it, 2 foot breaker wouldn't do it, what next?
Then I try to pull my tie rods off to install my turbo tie rod set. Screw driver in the joint, no luck, pipe wrench on the tie rod, no luck. What next?
Sprayed them both with PB blaster and left it for the night.
John Helgesen
Stahlwerks.com restoration and cage design
"Honest men know that revenge does not taste sweet"
Old 06-25-2003, 05:21 PM
Crusty Conservative
silverc4s's Avatar
John,
Can't be much help, but want to commend you a great thread title...;-)))
PS. I'm not John Walker for sure, but maybe if you bolted the flywheel back on the crank you could hold it stationary long enough to loosen the nut on the other end (you and a friend that is)...
Bill
69 911 T Targa, 2.4E w/carbs (1985-2001)
70 911 S Coupe, 2nd owner (1989- 2015)
73 911 T Targa, 3.2 Motronic (2001- )
Old 06-25-2003, 05:34 PM
Navin Johnson
TimT's Avatar
Tie rods
take equal weight hammers...and smack the steering arm 180 opposed
or since you are going to the turbo rods.. take a pickle fork and just pry the effers out// pickle fork, smack with BFH usually works
'69 911 GT-5
'75 914 GT-3
and others
Old 06-25-2003, 05:36 PM
You do not have permissi
john70t's Avatar
Give it a quick tap once in the clockwise direction, and lube the air tool.
Old 06-25-2003, 09:19 PM
When I was removing my old tie rods recently to replace w/ Turbos, I used a pipe wrench along with a long breaker bar, and they came off without a whimper (I didn't care if I mangled them). It still wasn't 'easy', but they did come off with no problem.
Old 06-26-2003, 05:02 AM
1fastredsc's Avatar
Send a message via AIM to 1fastredsc
If by belt pulley i assume you mean the one bolted to the crank. That bolt is torqued to a decent value. The only way you'll get it out without something to hold the flywheel is with a large impact, and even then you'll have to work it a bit. Usually the electric hammer impacts are pretty evil, but even then you should've left the flywheel on long enough to do this.
2007 Mazda 3 hatch
1972 Porsche 914 roller with plenty of holes to fix
Old 06-26-2003, 05:26 AM
Stahlwerks.com
jhelgesen's Avatar
Okay, crank pully is off. Bolted the flywheel to the crank, then a long bar to the flywheel. Then I used a 4 foot breaker bar to get the bolt off.
Next step, the tie rods.
John Helgesen
Old 06-27-2003, 04:37 PM
