915 experts please chime in
Hello gang
I’m hobbling together a 915 from a collection of parts. The main differential case is a
915/63 which according to my specs is from a 1980 SC. Now the center section leads to my question in that I don’t know if these two were together originally, it’s casting is
915 301 102 3R. It’s Aluminum of course and has the shaft coming out the side, the bearing races are tight and it bolts to the differential case with no problem. Should I have any concerns.
Thanks in advance.
Old 07-25-2024, 05:43 PM
I’ve swapped out lots of cases, shouldn’t be an issue.
Old 07-25-2024, 05:57 PM
gearhead
No issue
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 07-25-2024, 06:36 PM
915 case
Awesome, thanks for the advice
Old 07-25-2024, 07:31 PM
