SFR SFR is online now
3.6 conversion fiberglass tins
The (fiberglass) tins I have don’t have a mark for where to cut for the lower spark plug wire grommet. Or the gauge grommet in the rear of the engine.
Does anyone have the size of these oval grommets on paper so it can be used as template for cutout?
Old 07-17-2024, 05:09 PM
Bill Verburg's Avatar
the holes for the ignition wires in the side pieces is
1 1/4 x 2 "
You'' have to be more specific on the other one
Bill Verburg
Old 07-18-2024, 02:00 PM
This is the piece I was talking about, was able to measure and make the hole.
Would be nice if it came with a stickers where all the holes need to be cut…
Considering I had to trim up the front section, it may have been easier to modify original tins (I don’t think the cost of these tins was worth it).
Old 07-21-2024, 05:59 PM
where did you source those? i will likely need a set for myself in the near future...
1971 914-6 GT 3.6
1974 911
1976 911S leaf green backdate 3.2
Old 07-22-2024, 11:47 AM
I used Sheridan on mine, available in black or raw, they are designed specifically for a 3.6 in a 911 chassis, use w/ 3.2 console and regular 911 crossbar. For most purposes way better than using the 3.6 tin and console and3.6 crossbar, wish I had known about this 230yrs ago when I did my first 3.6 t/p, of course back then the 3.2 consoles were still in prototype form at the factory.
marking the holes isn't a big deal just place the steel versions that are removed on top of the f/g versions, voila
Bill Verburg
Old 07-22-2024, 01:14 PM
Bill - Where does the piece with the check mark go?
I got the kit in clear, will need to look up where, it was a while ago.
I modified the 3.6 engine bar (I didn’t want to pay what they’re getting for the 3.2 console these days).
Old 07-22-2024, 04:56 PM
Here's the stock 964 tin I started w/ way back when, used i on 964 and 993 engines
The problem is the tin is so deep it holds the engine down and spacers are required at the motor mounts
this causes issues w/ the exhaust hanging low, which can be a real nightmare
If I recall correctly the piece you asked about covers the left rear seen here naked
I agree that it's a sellers market for the 3.2 consoles but it's well worth it to keep looking an alternative is to make you own tins w/ less depth to them I believe that RSwannabe did that and kept the 3.6 cross bar and console, but I could be wrong about that too.
Bill Verburg
Old 07-23-2024, 08:30 AM
Here's the Sheridan f/g raw showing back pieces
This install uses the Sheridan w/ stock 3.6 crossbar and console, seems to work fine, I'm unsure if he had to use spacers but think not
Bill Verburg
Old 07-23-2024, 12:45 PM
