Mikesavina's Avatar
86 engine in 79 chassis wiring questions
So I purchased an 86 930 engine for my 79 930. I ditched the jetronic harness (ant the suggestions of others) and only connected the engine harness. At this point I have no buzz from my 6 pin cdi and no ignition. Have tried the CDI in another car and it worked fine. I do not have power to the red and white wire (terminal 15) from the harness. Any ideas would be greatly appreciated. Scratching my head here and the diagrams aren’t helping me much, could be my inability to read them properly.
Old 07-21-2024, 04:26 PM
Power to the red/white wire (terminal 15) is provided through the delayed action relay (aka delayed ignition cut off relay), and only when ignition key is turned on (Run and/or Start).
Check if this relay is good and have power.
See here for further details.
Gilles
RoW 88 Carrera coupé
Old 07-22-2024, 01:58 AM
Mikesavina's Avatar
Thanks. I’ll give that a look this evening. Ordered up some new wiring schematics as well since my old Haynes manual is a bit worse for wear
Old 07-22-2024, 04:54 AM
PCA Member since 1988
The Haynes manual is terrible for electrical stuff. The wiring diagrams do not even show color. Good that you ordered new diagrams.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 07-22-2024, 03:02 PM
Mikesavina's Avatar
Couldn’t agree more. It really is horrible
Old 07-22-2024, 03:41 PM
