Trailing Arm Odd Question
Hi,
I was hoping for some clarification the problem I am having with my 1977 911 S Targa.
Earlier this year, the threads pulled on the trailing arm, and I ended up sourcing a replacement locally.
In looking at the shock bolt length and comparing the old and new trailing arm, it seems that the bolt I have is the wrong length but it worked in my original trailing arm.
For clarification, original trailing arm part number 911 331 513 0R
replacement trailing arm part number 911 331 513 0R
The bolt length on the official parts PDF that I have lists it as M14 x 1.5 x 75MM however my bolt is M14 x 1.5 x 85MM.
I'm a bit stumped why my original trailing arm bolt length is different even though the part number hasn't changed.
I'll probably end up ordering the 75 MM bolt from my local Porsche dealership but was hoping someone here could explain why.
Thanks,
Kevin
Old 07-22-2024, 05:10 PM
dtwa's Avatar
The 84-86 PET lists almost the same part number (haven’t seen a Porsche number end with 0R before)):
911 331 513 06 Rear-axle trailing arm /L 1 CARRERA
911 331 514 06 Rear-axle trailing arm /R 1 CARRERA
And specifies an 85mm bolt.
900 082 054 02 Hexagon-head bolt M 14 X 1,5 X 85
Just another data point.
1985 Carrera 3.2 • Prussian Blue Metallic
Old 07-22-2024, 06:23 PM
dtwa's Avatar
I would run the longer bolt to get the extra thread engagement. —Dave
Old 07-22-2024, 06:26 PM
I actually can't run the longer bolt, it bottoms out and there is a gap between the end of the shock and the bolt.
I need to run the shorter bolt.
Old 07-22-2024, 07:37 PM
That's what washers are for.
Old 07-22-2024, 08:58 PM
nothing to see here
Any chance there’s something in the new-to-you trailing arm’s shock absorber mounting hole?
Old 07-23-2024, 02:23 AM
There’s 3 different length bolts.
We are dominated by the relatively small number of persons who understand the mental processes and social patterns of the masses. It is they who pull the wires which control the public mind.
Old 07-23-2024, 05:31 AM
An 85mm, 90mm and a 130mm.
Old 07-23-2024, 05:33 AM
76 and 77 used the longer 130mm bolt.
Old 07-23-2024, 05:38 AM
Shouldn’t bottom out with the correct washers.
Old 07-23-2024, 05:55 AM
The Porsche PDF I have calls out a 75 MM bolt, for a 74-77 911 Trailing Arm,
Does that mean there are 4 lengths?
I'm assuming the part numbers aren't the same for the trailing arm.
Old 07-23-2024, 07:48 AM
10MM is quite a difference to make up with washers.
Old 07-23-2024, 07:49 AM
Old 07-23-2024, 08:08 AM
I saw that image in the PDF but it doesn't mimic the connection to my trailing arm, that image has a bolt and nut where my trailing arm only has a bolt.
Old 07-23-2024, 08:15 AM
Those are washers not nuts.
Old 07-23-2024, 08:36 AM
Sorry for the confusion, the pic you posted matches the 78-83 PDF that I have, in the 74-77 PDF, it shows the bolt, two washers and a nut.
My original trailing arm only had a washer on the outside of the bolt, and nothing on the inside.
None of the images I have seen online also have a nut on the inside of the bolt connecting to the Trailing Arm, so i'm a bit confused.
Old 07-23-2024, 08:45 AM
My mid year had 75mm My SC 85mm. Perhaps your original 77’s were a transition to the next year 78 when the SC came out and your new used ones are the earlier shorter version. That’s all I can think of, I’m sure someone here has a lot more info than I do.
Old 07-23-2024, 09:01 AM
