Taxidodger
Fuel sensor calibration
Driving a new to me 911 SC and ran out of gas with tank showing slightly less than half. When full, gauge stays on 4/4 and empties at just below 2/4. Can this be recalibrated?
I have removed the float sensor, the float appears to move easily when I tip the tube. I have not dissembled the tube to clean the inside, is this recommended? Any advice to remedy the situation would be appreciated.
Old 06-17-2024, 05:59 AM
PCA Member since 1988
Yes, you can open it up and clean it.
Did the fuel low light come on? If not, then it's probably internally corroded. You might be able to clean that up, otherwise, get a new sender.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 06-17-2024, 11:02 PM
Taxidodger
Thanks for the reply. I opened up the sensor, cleaned it although it looked OK and reinstalled it. It worked fine for one fill-up cycle then gauge started flicking wildly once tank started to empty. I have subsequently replaced the sensor, but now the old problem is back. When tank is empty (I drained it) gauge shows just less than half, no fuel warning light. 5 gallons in, the gauge reads half, 10 gallons in, between half and three quarters. Is this a job for North Hollywood speedometers?
Old 07-24-2024, 02:38 PM
First test your gauge. If you disconnect the wire from the gauge to the sender, it should go to either F or E (I don't remember which). If you ground that wire, it will go the reverse. Ground the wire to the fuel low light and it should come on.
Old 07-24-2024, 02:58 PM
