Help Identify this Tach 10K 4 cylinder ...
I have a strange tachometer in my possession...You have to love swap meets!
112 mm diameter
10K rpm silver button
date code 3.67
4zyl.4Takt
230/3/2
stamped 12v/14000Imp with the 14 over stamped with 20 so 12v/20000Imp
date stamped 3.67 and blue ink stamped 225 4 67
Face plate part number 901 741 302 06
its been opened. flat screws show wear
So, what's the deal with a March 1967 10k tach for a 4 cylinder ( or maybe an 8 with twin plug? )
Thanks, Scott
Old 07-22-2024, 11:47 AM
Flat Six
Flat Six's Avatar
Cool tach; no help from me but thanks for sending me down a 10k rabbit hole!
Found this, you might be interested:
https://www.early911sregistry.org/forums/showthread.php?75266-10-000-rpm-porsche-tachometer-can-anyone-help
Dale
1985 Carrera 3.2 -- SOLD
2026 Jaguar F-Pace / 2025 Ford Bronco Sport
Old 07-22-2024, 12:00 PM
I spent a weekend down that hole! nothing definitive yet.
Old 07-22-2024, 12:10 PM
gearhead
It’s been redone. Not original.
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 07-23-2024, 06:19 AM
Matt is correct! I've seen many like this and have built many myself. Your tach started life as a standard 67/68 912 tachometer. The factory 10K faces were available from Porsche until about 10 years ago so many were installed on these 10K tach conversions.
The 20 was stamped over the 14 when the conversion was done to signify that it was converted to 10,000 RPM for a 4-cyl engine. The original 14000IMP signifies 7,000RPM 4-cyl. If it were setup for a 6-cyl the impedance would be 30000
1970 911E Sportomatic Albert Blue
1971 911T Sunroof Coupe w/ Twin Plug 2.5 MFI
1973 911E Glacier Blue
1973 911E RSR Tribute Viper Green w/ 3.5 Twin Plug MFI
Old 07-23-2024, 12:44 PM
RDM RDM is offline
Coram Deo
RDM's Avatar
Love this place.
Dru
1980 911SC Targa • Petrol Blue Metallic • Cork special leather • Sport Seats • Limited Slip • 964 Cams • SSIs • Rennshifter
• 1990 250D Opawagen • 1995 E220T Sportline Familienwagen • 1971 280SE Beverly... hills that is • 1971 Berlina 1750 Faggio •
Old 07-24-2024, 03:06 PM
