At the end of the day this and your other thread should be sticky’s as incredibly helpful for the next guy with lots of knowledge and information shared. |
Dyno Data 1.750" Headers vs 1.625" Headers
Here is the head to head dyno data, same engine (2.8L 9.8:1 CR 911S MFI cams) 1.750" headers versus 1.625" headers.
http://forums.pelicanparts.com/uploa...1724900350.jpg And before somebody asks about the scale labeling, it's 0 to 250 either ft-lbs or hp full scale with 25 ft-lbs or hp divisions. See previous dyno graph for reference. http://forums.pelicanparts.com/uploa...1724900584.jpg |
Dan those are good numbers and good data thanks for sharing. I would be happy with that setup
Great to see these results and I really appreciate the transparency!
I'm curious to see how the new cam affects these numbers if you decided to dyno again. +1 for a vote to sticky this and your other thread, I believe they are a big positive to the community! |
More impressive than the power gains of 6hp, the smaller headers seems to have helped shorten the flat spot at 3500RPM. Wondering is smaller headers or a bit of back pressure from the muffler would smooth that out even more.
Dan, do a whole bunch more dyno pulls...Let's spend more of Dan's money!! ;) |
This is great data - thank you for sharing. Nice to see you filled in that drop around 3,500 a bit and picked up some top end as well! Looking forward to the next test.
Sent from my iPad using Tapatalk Pro |
Need to make one change at a time so effects are not blurred. Change the cams and dyno that then change the headers and re-run.
What is the difference between the 1-5/8 headers you have now and the set to be tested? We just designed and built a complete system for a similar 2.8L engine. The headers make the power but the muffler has to stay out of the way. The system is not designed properly if adding back pressure enhances performance. The muffler has to complement the flow and velocity produced by the headers best it can. That is why you cannot slap on a one-size-fits-all muffler and expect anything good to happen. OE dual inlet mufflers have 1-7/8" inlets. Inlet size and internals need to match the header secondary size. Ours start at 2" and increase incrementally to 2.5" depending on engine flow requirements. Muffler internal flame tubes are also sized to match (no baffles). |
Thanks for sharing this, it will be a valuable addition to the knowledge base here for a very, very, long time. I do look forward to the dyno plot with the new cams, will be an equally interesting comparison. PS - That's a healthy 2.8! Do mustang dynos still have a reputation of being "heartbreakers" that under-report power numbers when compared to Dynojets, or have they tweaked the calibrations to bring them more in line with the competition? |
Regarding the increase in top end max HP, Gary said the engine wanted 2 degrees more timing at the top with the smaller headers so that may be where we got the increase in max HP from 229 to 236. |
The larger headers lost velocity which impacts scavenging. The pulse timing gets diluted as the flow slows then power falls off. That is why the smaller headers needed a bump in timing, to better synchronize the pulse timing with the scavenging events.
