Exhaust Header Size for My Rebuilt 2.7L Motor
I decided maybe it would be best to start a new topic thread to continue the discussion about the best header OD size for my recently rebuilt 2.7L motor.
We (mb911, mikedsilva, scarceller, winders and others) have been having a very good, enriching, knowledgeable discussion on this topic over on my "CIS to ITB EFI conversion" thread. But that thread has run it's course as a "how to" for like minded folks that want to successfully install Al Kosmal's X-Faktory CIS to ITB EFI conversion kit. As a recap, I decided towards the end of the rebuild of my 1975 911 Carrera 2.7L engine to employ the "bigger is better" philosophy in the selection and installation of 1.750" OD exhaust headers. All of the more experienced members of this forum quickly pointed out the 1.750" OD headers were way too big for my little 2.7L motor and that 1.50" OD headers were most appropriate. Well, I had the 1.750" OD headers (Bursch Exhaust BX.9258.SS) installed so I ran with them for the initial start up, 1000 mile break-in. and dyno tuning run. The dyno tuning results clearly showed there was a problem: a "hole" in the torque curve between 3000-4000 rpm. ![]() That dyno result was not acceptable to me, so I have ordered a set of 1.625" OD headers (Bursch Exhaust BX.9158.SS) and a set of 1.50" OD headers (Dansk 1620800470 & 1620800480) which I will install and run on the dyno once I receive them. Then based on the dyno data, I will decide which size header (1.50" OD or 1.625" OD - I have already conceded that 1.750" OD is not right) to run given my intended use for the car as a weekend canyon carver. I will receive the 1.625" OD headers tomorrow, so they will be the next exhaust option that I will run on the dyno (my next dyno appointment is Aug 28th), and I will share the dyno data as it becomes available.
Dan 1975 911 Carrera "CIS to ITB EFI conversion" thread Updated (2) Table of Contents pg17 post 339 Last edited by dannichols1474; 08-18-2024 at 10:26 PM.. Reason: correct mikedsilva's name |
Racer
Dan,
I am running some 1 3/4" custom headers William Knight has made so I don't need another set of headers. Plus, I am not a fan of the Bursch headers in any O.D. Here is Williams contact info: William Knight knightrace@mac.com 615.969.4917
Scott Winders PCA GT3 #3 2021 & 2022 PCA GT3 National Champion 2021 & 2022 PCA West Coast Series GT3 Champion |
Dan the 1.625 headers will work better for sure. I want to put this information down for others to see so they can reference it.
ALL tubing is measured OD ALL pipe is measured ID until over 12” ( that is of no concern to us folks) ALL headers when advertised size are referring to OD. In my many years of doing this and hundreds of sets made/sold I have never seen it different. For example the original SSI was 1.5” with an ID of 1.375 because a wall thickness of .0625 and no they weren’t metric tubing and most the headers you see are not metric tubing. I hope this helps someone else
Ben 89 944,85.5 944 914-6 2.4s GT tribute. 914-6werkshop.com |
Hi Ben,
Thank you, that is good info for all of us. I will add that when I was looking on the internet for off the shelf 1.50" OD headers without heat exchangers yesterday, the vast majority of the units I saw advertised were 1.625" (41mm) and advertised in US measurements. The only exception to the tube size in OD rule I saw was from Patrick Motorsports (Porsche 911 Exhaust Header Set With Street Adapters - 1-1/2 Inch (1.50") (EXH P911 112SA)) and those units specifically state "Exhaust Headers - Porsche 911 - 1.50 in. / 38mm I.D. Primaries - Mild Steel - includes Street Muffler Adapter Set" in their description.
Dan 1975 911 Carrera "CIS to ITB EFI conversion" thread Updated (2) Table of Contents pg17 post 339 Last edited by dannichols1474; 08-18-2024 at 10:28 PM.. |
Dan I am 99% sure that PMS is identifying OD then ID in that description which makes it even more confusing. I also am almost certain William Knight is having his headers made elsewhere but that could be a bad rumor but regardless those are quality units.
Yes , if PMS unit is 1.50” OD , then their description is very confusing as 1.50” = 38mm.
Dan 1975 911 Carrera "CIS to ITB EFI conversion" thread Updated (2) Table of Contents pg17 post 339 |
It is for sure. Have you looked into MSDS headers and having them ceramic coated. If you call Marty he is extremely knowledgeable and has been doing this since the 70s
Crotchety Old Bastard
We've been designing and building custom headers specific to application for years.
There is a lot more to achieving an optimal torque curve and HP number than OD tubing size. Muffler design is also extremely important, we build the entire exhaust as one system where the flow is optimized from exhaust port to tailpipe. You can't expect to slap on a set of generic headers and a one size fits all muffler and have anything good come of it. Here is the info we request: Displacement C/R Induction Cam profile Head work and I/E port sizes Redline RPM Expected torque curve and peak RPM Expected HP and RPM How the car will be driven and if it is track or street or both How loud and where do you want the tailpipe(s) to exit Do you need heat exchangers With this information a properly optimized system can be designed and produced. I cannot imagine spending the money these engines cost to build today and leaving so much on the table using an off the shelf exhaust system. .
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
You want to maintain a balance of capacity between the intake event, the combustion event and the exhaust event.
Here's a comparison of flow volume at 100% VE for the different sized combustion events, notice that a 2.7 @ 8k flows the same as a 3.8 @5.6k ![]() a close up of the above ![]() when sizing the intake or exhaust the idea is to keep flow up but also to though put the necessary volumes, too big a flow velocity drops too small and unwanted pressure builds the exhaust tube length and width is also a tuning tool to constructively put a neg. pressure wave at the exhaust port @ TD compression overlap when both valves are off their seats, The more overlap the more constructive this signal is. The purpose here is to draw extra gasses out of the exhaust port and to draw extra gasses in through the intake port. But this is only efficiently done w/ open headers w/ the right geometry and topology. This neg. acoustic signal strength is solely determined by the cross section area of transitions in the exhaust, the largest being at the collector outlet in an unmuffled system. ![]() muffled systems have this refracted wave but in weakened form and from smaller cross section transitions found in the exhaust. There is also a destructive rarefication presented to the exhaust @~2k rpm, this one inhibits flow, it can usually be detected by a drone in the exhaust noise. different exhaust cross section areas mostly move the torque peak up or down a few hundred rpm a long as they are close to what's need to maintain flow velocity, the gasses leave the exhaust port @`~120m/s, you want to keep that velocity up despite the slowdown caused by cooling and expansion ![]() length of the primary tubes merely rocks the the torque curve around the torque peak ![]() to actually move the torque curve and change it's shape you need to play w/ cylinder pairings, using what's called Tri y merges vs the usual 3 or 4 into 1 collector, it's easier to see w/ a 4 cyl or a V8 than w/ a flat 6 because the flat 6 has ideal pairings w/ the 3 into 1 we mostly all use. ![]() to get a similar result from a flat 6 you need to do something like this
Dan is that centerline measurements? Pretty long headers
Centerline is the best way. You can take a piece of string and hold it right where it goes into the collector, then work your way down the tube and once at the flange mark the string and lay it out flat on a table and measure.
Critical aspect of measuring tube length at the center line is to replicate the pathway of the center of the tube by staying in the center of the bend radius, not going to the outside or inside of the bend. This may seem obvious but may not be to everyone. The spec we use on primary length is +/- 1/4" to remain true equal length.
VE Table After 1st Auto Tune Session With 1625 Headers
This morning I took the car out for an auto tuning session after installing the 1.625" OD headers. I ran the car mainly on the freeway at idle to about 4800rpm and mainly 0 to 60% TPS with a couple of WOT pulls.
Difference Report from TunerStudio of the After (left VE table) versus Before (right VE table). ![]() On the right side table (1.750" headers) you can see most of the VE cell values increased (red numbers) with the 1.625" headers in the target region. Since the AFR targets have not changed, increasing VE cell values means air flow at the rpm / load for those increased cells is also increasing. That means when I run the engine on the dyno with the 1.625" headers, the torque should also increase (more air & fuel, bigger bang, more pressure). There will probably still be a dip in the torque curve at 3000-4000 rpm, but it should be less. Then I will install and run the 1.500" OD headers and see what that data shows me.
This is great VE comparison data on the two headers - thank you for posting the analysis.
It looks like you have a nice bump 3k-4.5k with the new headers --- and even better, no loss on the top end. I look forward to seeing the dyno and 1.5" header comparison. |
Thx Ben for the MSDS,inc. honorable mention !
We mfg this 'Merge collector style>> much like the way the factory built their competition racing headers back in the '70s. 1.625" od is correct for a 2.7L; and as a side note we mfg the three popular sizes 1.500" 1.625" and 1.750" od's...and No upcharges for the larger sizes either. Three styles of 1,650°f Ceramic coating availble. www.msdsinc.com
Porsche builds the 21st century 9146 so easy...even a Cayman can do it ! |
Racer
https://forums.pelicanparts.com/911-engine-rebuilding-forum/940145-how-primary-length-measured.html#post9406586 The key is to keep the string at 90% of any turn...this means you may not be able to measure it without measuring in sections.
(man/dude)
I also was very interested to see the lack of change in the upper range of the ve tuning, but it was unclear if the autotune session included any activity in the upper RPM ranges?
Heavy Metal! Part Deux - The Carbon Copy Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD) 85 Coupe - The Rot Rod! AX beater Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911 |
When I ran the auto tune session I stayed in the 2500-4800 rpm range to focus on changes in the 3000 - 4000 rpm region of the VE table - so cell values in VE table above 5000 rpm haven't seen the effect of the 1.625" headers.
Dan 1975 911 Carrera "CIS to ITB EFI conversion" thread Updated (2) Table of Contents pg17 post 339 Last edited by dannichols1474; 08-18-2024 at 10:22 PM.. |
PCA Member since 1988
The string method is close enough. The difference of an inch or so will make very little difference in the computation of resonances in the exhaust primaries.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
1.750" OD header - #1: 34 3/8", #2: 33 1/2", #3: 33 1/8"
Dan 1975 911 Carrera "CIS to ITB EFI conversion" thread Updated (2) Table of Contents pg17 post 339 Last edited by dannichols1474; 08-18-2024 at 10:23 PM.. |
