-   -   frequency valve differences (http://forums.pelicanparts.com/porsche-911-technical-forum/1165466-frequency-valve-differences.html)
Drooman 08-11-2024 07:21 AM
83 SC frequency valve failure.. kind of an unusual failure i think because not only did it stop working it was also pumping fuel out around the electrical pins.
Anyhow shopping for a replacement and i see different applications ... the original one shows bosch # 0280150300 but see offerings listing the SC also showing 0280150306.
does it matter? is the difference strictly in the hose attachment?
ahh911 08-11-2024 08:26 AM
Contact Tony, boyt911sc, he might have a replacement and answers.
Phil
AndrewCologne 08-11-2024 09:32 AM
Beside asking Tony, as the best source for CIS components, you can see the differences listed here:
http://andrewcologne.bplaced.net/911/Bosch_Injector_data.xls.zip
BR
pmax 08-11-2024 12:40 PM
BR
Not sure about anyone else, I'm not opening a "zip" file from a "random link", no offense.
Could you post a screenshot of the info ?
AndrewCologne 08-11-2024 05:09 PM
Its not a "random link", ... its a link to my webspace.
It's a large listing of all injectors no screenshot possible.
Drooman 08-12-2024 05:31 AM
I appreciate the replies although I couldn't get the link to work.... im using mac OS
I did find your site but didn't see a way into the library
AndrewCologne 08-12-2024 10:03 AM
The link works, Im using Mac OS and Safari as well.
What error occurs that won't let you download the file?
Here, not zipped as original xls file:
proporsche 08-12-2024 12:22 PM
Andrew it does not do anything..when you click on it it does not even open any page 2 miliseconds and nada..
Schulisco 08-12-2024 12:52 PM
On windows computers, right click on the link of Andrew's Posting #7 and download it directly. After that click on "keep file". Then open it manually by double click onto the downloaded file...
Most browsers tend in the meantime not to access such direct links on files due to cyber attacks in the past after normal clicking onto such links...
@Andrew: I could transform the Excel file with Excel to a html web page, probably this might be an easy way to deploy it instead of a zipped Excel file...
Thomas
AndrewCologne 08-12-2024 01:07 PM
Hi Thomas, good approach ... I tried as well
Bosch injectordata
Ivan, just let me know if it works
proporsche 08-12-2024 11:20 PM
Bosch injectordata
yup ,this link works fine;-)
Ivan
Drooman 08-13-2024 08:40 AM
yes works! thank you
