frequency valve differences
83 SC frequency valve failure.. kind of an unusual failure i think because not only did it stop working it was also pumping fuel out around the electrical pins.
Anyhow shopping for a replacement and i see different applications ... the original one shows bosch # 0280150300 but see offerings listing the SC also showing 0280150306. does it matter? is the difference strictly in the hose attachment? |
Contact Tony, boyt911sc, he might have a replacement and answers.
Phil
81 SC. 930/16 (us model) |
http://andrewcologne.bplaced.net/911/Bosch_Injector_data.xls.zip BR
911 SC 3.0, 1982, black, US model – with own digital CPU based lambda ECU build and digital MAP based ignition control All you need to know about the 930/16 and 930/07 Lamba based 911 SC US models: https://nineelevenheaven.wordpress.com/english/ |
Still here
Could you post a screenshot of the info ? |
Its not a "random link", ... its a link to my webspace.
It's a large listing of all injectors no screenshot possible.
I appreciate the replies although I couldn't get the link to work.... im using mac OS
I did find your site but didn't see a way into the library Last edited by Drooman; 08-12-2024 at 05:38 AM.. |
The link works, Im using Mac OS and Safari as well.
What error occurs that won't let you download the file? Here, not zipped as original xls file: http://andrewcologne.bplaced.net/911/Bosch_Injector_data.xls
Andrew it does not do anything..when you click on it it does not even open any page 2 miliseconds and nada..
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
On windows computers, right click on the link of Andrew's Posting #7 and download it directly. After that click on "keep file". Then open it manually by double click onto the downloaded file...
Most browsers tend in the meantime not to access such direct links on files due to cyber attacks in the past after normal clicking onto such links... @Andrew: I could transform the Excel file with Excel to a html web page, probably this might be an easy way to deploy it instead of a zipped Excel file... Thomas
1981 911 SC Coupé, platinum met. (former tin (zinc) metallic), Bilstein shocks, 915/61,930/16,WebCam20/21, Dansk 92.502SD,123ignition distributor with Permatune box as amplifier,Seine Systems Gate Shift Kit,Momo Prototipo. Want to get in touch with former owners of the car. Last registration in US was in 2013 in Lincolnshire/lL. |
Ivan
