What Transmission oil fill pump?
What pump do you use to fill your transmission?
My old pump broke, so I need a new one.
Are the cheap electric pumps any good? Does anyone use the syringe style?
Old 09-13-2024, 09:50 PM
proporsche's Avatar
use gravity ,safe the money for beer;-)
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 09-13-2024, 11:19 PM
Bill Douglas's Avatar
I'm the same a Ivan. It's all about the beer. Let gravity do the hard work.
Old 09-14-2024, 12:26 AM
Location: Just a little north of 13669/Nation's capital
Send a message via AIM to brighton911
Gravity method for me too. It doesn't take long and never breaks down I (unless the earth stops spinning).
1986 Targa Guards Red
2021 MT09 SP
Old 09-14-2024, 04:16 AM
That's fond- just deglaze
Hi Error Margin- Here's my story with images (used gravity & 5/8" OD x 1/2" ID)...
https://forums.pelicanparts.com/porsche-911-technical-forum/1099549-915-transmission-fluid-change-hose-dimensions.html
Missed Approach
Petra- 1986 Coupe
Old 09-14-2024, 06:33 AM
Send a message via AIM to fintstone
I recently bought this one to fill the differentials and transfer case of my 4Runner. It worked great for that. It attached right to the gallon jug and pumped a massive amount quickly/easily.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 09-14-2024, 09:01 AM
I use gravity for the 911. Sir Isaac Newton method works.
For very hard to fill cars, I have a pressurized system. Faster and cleaner than small hand pumps.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 09-14-2024, 10:52 AM
Still here
pmax's Avatar
As mentioned, gravity.
Add time and patience. Warm weather helps.
Old 09-14-2024, 12:55 PM
proporsche's Avatar
yup, if you have sunny days leave the oil to warm up there...in winter(if i have a trans. service) i use my tiled stove from 1841 , to warm up the oil...in the same time i use it for our chickens fireclay bricks to warm them up at night...this way we have eggs even in winter;-)
Old 09-14-2024, 01:52 PM
HarryD's Avatar
Done it several ways:
https://forums.pelicanparts.com/11418790-post6.html
https://www.harborfreight.com/multi-use-transfer-pump-63144.html
https://www.harborfreight.com/search?q=suction%20gun
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 09-14-2024, 07:59 PM
proporsche's Avatar
one more thing to the OP..
Make sure your car is in a level,nor just lift the end.This way you will be able,no matter which techniques you will use, to fill the the trans. with correct amount of oil.....
Ivan
Old 09-15-2024, 12:42 AM
Same as Ivan, gravity method through a piece of garden hose repurposed for this job. I always warm the new oil up in a bucket of hot water first, makes quite a difference in time to pour
Old 09-15-2024, 01:29 PM
shoooo32's Avatar
I like the OEM Tools pump. The adapter threads into the transmission and the hose has a valve on the end to shut off the flow. It's $100 but I've spent way more on dumber stuff.
-Tony
Instagram: @Pablo_the_Porsche | @RuchlosRallye
AchtungKraft #002
Old 09-16-2024, 09:50 AM
