72T Headlights not working
Before I spend a bunch of time I thought I'd ask...
Headlights not working on my 72T via the dash switch - but when I pull the stalk the high beams come on, and then when I pull the dash light switch (at the same time) they drop to low beam. Thoughts? |
Hi/low relay working? Round relay, Up behind the fuel gauge.
I'll take a look - have a couple of spare relays on hand - many thanks.
Did the lights used to work properly? What changes have you made since then? |
Never had an issue with the headlights in the past - car was stored over the cold season - was unaware of any issues prior to parking it up for winter.
Fuses all look good. Only recent changes were a new fuel pump relay (top popped off the old one), and a new high torque starter (OEM unit was getting sticky). |
Check the fusee on both sides with a test light or multimeter.
Yup, bad switch, all done - everything working just fine.
| All times are GMT -8. The time now is 09:06 PM. |
