nigel911's Avatar
72T Headlights not working
Before I spend a bunch of time I thought I'd ask...
Headlights not working on my 72T via the dash switch - but when I pull the stalk the high beams come on, and then when I pull the dash light switch (at the same time) they drop to low beam.
Thoughts?
Old 08-11-2024, 05:33 PM
ROW '78 911 Targa
timmy2's Avatar
Hi/low relay working? Round relay, Up behind the fuel gauge.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 08-12-2024, 04:04 AM
nigel911's Avatar
I'll take a look - have a couple of spare relays on hand - many thanks.
Old 08-12-2024, 08:34 AM
HarryD's Avatar
The high-lo relay is not the same as the common round relays.
Did the lights used to work properly? What changes have you made since then?
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 08-12-2024, 08:51 AM
nigel911's Avatar
Never had an issue with the headlights in the past - car was stored over the cold season - was unaware of any issues prior to parking it up for winter.
Fuses all look good.
Only recent changes were a new fuel pump relay (top popped off the old one), and a new high torque starter (OEM unit was getting sticky).
Old 08-12-2024, 11:28 AM
HarryD's Avatar
Check the fusee on both sides with a test light or multimeter.
Harry
2020 MB E350 4Matic
Old 08-12-2024, 11:33 PM
nigel911's Avatar
Yup, bad switch, all done - everything working just fine.
Old 09-15-2024, 12:19 PM
