-   -   Torque specs for engine temp switches (http://forums.pelicanparts.com/porsche-911-technical-forum/1165586-torque-specs-engine-temp-switches.html)
Gretz 08-13-2024 12:50 PM
I've having a heck of a time finding the torque specs for these items. I assume the values are probably the same. Could someone please provide?
For a 1982 SC:
Thermotime Switch (left chain cover)
15* Temp Switch (right chain cover)
35* Temp Switch (rear breather, TOD area)
Thanks!
wazzz 08-14-2024 04:05 AM
18.43 Ft-Lbs (or 25 N-m) for all three.
Torques can all be found here : https://www.torkspec.com/torkspecme.aspx?KI=34-2.7L-164ci-F6-911
I used those for 2.7 CIS as there is no 3.0 available, but values are probably the same.
Schulisco 08-14-2024 04:28 AM
No particular torque values mentioned in the tech spec book for the SC.
Afaik all of them are M14x1.5 threads. For them Porsche recommends max. 25Nm. M10x1.5 like the oil pressure sesnsor switch only 20Nm max., oil pressure sensor M18x1.5 max. 35Nm.
Thomas
Gretz 08-14-2024 05:44 AM
