82 911 SC - Ancora Imparo
Torque specs for engine temp switches
I've having a heck of a time finding the torque specs for these items. I assume the values are probably the same. Could someone please provide?
For a 1982 SC: Thermotime Switch (left chain cover) 15* Temp Switch (right chain cover) 35* Temp Switch (rear breather, TOD area) Thanks!
Ethan 1982 911 SC - Wine Red Metallic Coupe |
18.43 Ft-Lbs (or 25 N-m) for all three.
Torques can all be found here : https://www.torkspec.com/torkspecme.aspx?KI=34-2.7L-164ci-F6-911 I used those for 2.7 CIS as there is no 3.0 available, but values are probably the same.
Gilles RoW 88 Carrera coupé |
No particular torque values mentioned in the tech spec book for the SC.
Afaik all of them are M14x1.5 threads. For them Porsche recommends max. 25Nm. M10x1.5 like the oil pressure sesnsor switch only 20Nm max., oil pressure sensor M18x1.5 max. 35Nm. Thomas
1981 911 SC Coupé, platinum met. (former tin (zinc) metallic), Bilstein shocks, 915/61,930/16,WebCam20/21, Dansk 92.502SD,123ignition distributor with Permatune box as amplifier,Seine Systems Gate Shift Kit,Momo Prototipo. Want to get in touch with former owners of the car. Last registration in US was in 2013 in Lincolnshire/lL. |
