LinkBack | Thread Tools |
Rating: ![]() |
Momo collector
Looking for a performance diagram of a 3 litre SC engine with Solex carbs
Does anyone have a performance diagram of a 3 liter SC engine with Solex 40 carburettors? It would be great if I could get it. Many thanks
Mads from https://www.patipatina.com |
gearhead
What do you mean by performance diagram? No 3l engine was ever delivered with carbs. It’s a cis engine. Any factory diagrams, like vacuum lines, would be for cis. What information specifically do you require?
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
Momo collector
Hey Matt,
thanks for your reply. I know, the SC engine came with CIS but I have rebuilt an engine block and installed Solex carbs for purity reasons. Here's the thing: In order to get a registration in a weird European country, I need a performance chart aka dyno chart of a similar engine (3 litre SC engine) with Solex carbs. Thing is, there is no place even in a 100 mls radius that could do a dyno run and I am not allowed to drive the car until it gets a rego. The registration authority is fine with a similar dyno chart with a same (near) spec engine. Hope that makes sense! Cheers, Mads
The 9 Store
Make one up on your computer.
I think I just said the quiet part out loud.
All used parts sold as is. |
Here is one for Webers. Change the name.
Weber Dyno Result |
Banned
Momo collector
Got what I needed - thanks guys for the help ✌️
PCA Member since 1988
It's a spam bot.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
